Report missing?
mmoyse
Report missing?
Post by mmoyse »
The plugin is supposed to install a report, I don't seem to have it. Is it downloadable from anywhere?
Re: Report missing?
It should be called P4A - Application Management Report and available is Automate major version is >= 110
If you have access to SQL see if you can see it installed in database
Select count(*) FROM ltreports WHERE `ReportTitle` = 'P4A - Application Management Report'
Should get a "1"
mmoyse
Re: Report missing?
Post by mmoyse »
It returns 0.
I'm on 2021.4
Re: Report missing?
Copy the following SQL code and execute it. It should add to the LTReports table the report.
INSERT INTO `ltreports` (`ReportTitle`,`ReportCategoryID`,`DateAdded`,`UserIDAdded`,`DateLastUpdate`,`UserIDLastUpdate`,`Description`,`ReportData`,`IsSubReport`,`GUID`) VALUES ('P4A - Application Management Report',20,NOW(),3,NOW(),3,'This report provides you with a simple view of managed applications and their versions\n\n Report Version 3.0.0.8 .\n\nHttp://www.plugins4automate.com','/// <XRTypeInfo>\r\n///   <AssemblyFullName>ReportCenterPlugin, Version=1.3.11007.8, Culture=neutral, PublicKeyToken=null</AssemblyFullName>\r\n///   <AssemblyLocation>C:\\Users\\sanderson.SQUIDDEV1\\AppData\\Local\\Temp\\tmpE7E9.tmp</AssemblyLocation>\r\n///   <TypeName>ReportCenterPlugin.EndUserDesigner.LTXtraReport</TypeName>\r\n///   <Localization>en-US</Localization>\r\n///   <Version>14.2</Version>\r\n///   <References>\r\n///     <Reference Path=\"C:\\Users\\sanderson.SQUIDDEV1\\AppData\\Local\\Temp\\tmpE7E9.tmp\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System\\v4.0_4.0.0.0__b77a5c561934e089\\System.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Configuration\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Configuration.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Xml\\v4.0_4.0.0.0__b77a5c561934e089\\System.Xml.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Data.SqlXml\\v4.0_4.0.0.0__b77a5c561934e089\\System.Data.SqlXml.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Security\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Security.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Core\\v4.0_4.0.0.0__b77a5c561934e089\\System.Core.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Numerics\\v4.0_4.0.0.0__b77a5c561934e089\\System.Numerics.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.VisualBasic\\v4.0_10.0.0.0__b03f5f7f11d50a3a\\Microsoft.VisualBasic.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Windows.Forms\\v4.0_4.0.0.0__b77a5c561934e089\\System.Windows.Forms.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Drawing\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Drawing.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\Accessibility\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\Accessibility.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Deployment\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Deployment.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Runtime.Serialization.Formatters.Soap\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Runtime.Serialization.Formatters.Soap.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Management\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Management.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Configuration.Install\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Configuration.Install.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Runtime.Serialization\\v4.0_4.0.0.0__b77a5c561934e089\\System.Runtime.Serialization.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.ServiceModel.Internals\\v4.0_4.0.0.0__31bf3856ad364e35\\System.ServiceModel.Internals.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\SMDiagnostics\\v4.0_4.0.0.0__b77a5c561934e089\\SMDiagnostics.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.JScript\\v4.0_10.0.0.0__b03f5f7f11d50a3a\\Microsoft.JScript.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Xml.Linq\\v4.0_4.0.0.0__b77a5c561934e089\\System.Xml.Linq.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Runtime.Remoting\\v4.0_4.0.0.0__b77a5c561934e089\\System.Runtime.Remoting.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_32\\System.Web\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Web.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_32\\System.Data\\v4.0_4.0.0.0__b77a5c561934e089\\System.Data.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_32\\System.Transactions\\v4.0_4.0.0.0__b77a5c561934e089\\System.Transactions.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_32\\System.EnterpriseServices\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.EnterpriseServices.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.DirectoryServices\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.DirectoryServices.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Runtime.Caching\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Runtime.Caching.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Web.RegularExpressions\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Web.RegularExpressions.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Design\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Design.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_32\\System.Data.OracleClient\\v4.0_4.0.0.0__b77a5c561934e089\\System.Data.OracleClient.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Drawing.Design\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Drawing.Design.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Web.ApplicationServices\\v4.0_4.0.0.0__31bf3856ad364e35\\System.Web.ApplicationServices.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.ComponentModel.DataAnnotations\\v4.0_4.0.0.0__31bf3856ad364e35\\System.ComponentModel.DataAnnotations.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.DirectoryServices.Protocols\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.DirectoryServices.Protocols.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.ServiceProcess\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.ServiceProcess.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Web.Services\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Web.Services.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.Build.Utilities.v4.0\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\Microsoft.Build.Utilities.v4.0.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.Build.Framework\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\Microsoft.Build.Framework.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Xaml\\v4.0_4.0.0.0__b77a5c561934e089\\System.Xaml.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.Build.Tasks.v4.0\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\Microsoft.Build.Tasks.v4.0.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Data.Linq\\v4.0_4.0.0.0__b77a5c561934e089\\System.Data.Linq.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraScheduler.v14.2.Core.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\Interfaces.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\Devart.Data.MySql.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\Devart.Data.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraReports.v14.2.Extensions.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.Utils.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\UIAutomationClient\\v4.0_4.0.0.0__31bf3856ad364e35\\UIAutomationClient.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\WindowsBase\\v4.0_4.0.0.0__31bf3856ad364e35\\WindowsBase.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\UIAutomationTypes\\v4.0_4.0.0.0__31bf3856ad364e35\\UIAutomationTypes.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\UIAutomationProvider\\v4.0_4.0.0.0__31bf3856ad364e35\\UIAutomationProvider.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_32\\PresentationCore\\v4.0_4.0.0.0__31bf3856ad364e35\\PresentationCore.dll\" />\r\n///     <Reference Path=\"C:\\WINDOWS\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Windows.Input.Manipulations\\v4.0_4.0.0.0__b77a5c561934e089\\System.Windows.Input.Manipulations.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.Utils.v14.2.UI.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraBars.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraEditors.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraTreeList.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraRichEdit.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraPrinting.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraVerticalGrid.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraCharts.v14.2.Extensions.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraCharts.v14.2.Wizard.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraNavBar.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraPivotGrid.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.CodeParser.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraLayout.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraWizard.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraGrid.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraScheduler.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraRichEdit.v14.2.Extensions.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.XtraSpellChecker.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Program Files (x86)\\LabTech Client\\DevExpress.SpellChecker.v14.2.Core.dll\" />\r\n///   </References>\r\n///   <Resources>\r\n///     <Resource Name=\"XtraReportSerialization.ApplicationsComputer\">\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// aXplXSogMTAwLCAwKSwgMGYpLA0KJyUpJykgAYUESWlmKEdldE1vbnRoKFtQYXRjaFRpbWVdKSA9PSAxLCAnTm90IFNldCcsDQpJaWYoR2V0TW9udGgoW1BhdGNoVGltZV0pID09IDIsICdTdW5kYXlzLCAnLA0KSWlmKEdldE1vbnRoKFtQYXRjaFRpbWVdKSA9PSAzLCAnTW9uZGF5cywgJywNCklpZihHZXRNb250aChbUGF0Y2hUaW1lXSkgPT0gNCwgJ1R1ZXNkYXlzLCAnLA0KSWlmKEdldE1vbnRoKFtQYXRjaFRpbWVdKSA9PSA1LCAnV2VkbmVzZGF5cywgJywNCklpZihHZXRNb250aChbUGF0Y2hUaW1lXSkgPT0gNiwgJ1RodXJzZGF5cywgJywNCklpZihHZXRNb250aChbUGF0Y2hUaW1lXSkgPT0gNywgJ0ZyaWRheXMsICcsDQpJaWYoR2V0TW9udGgoW1BhdGNo\r\n/// VGltZV0pID09IDgsICdTYXR1cmRheXMsICcsICdFdmVyeWRheSwgJykpKSkpKSkpDQorIElpZihHZXRNb250aChbUGF0Y2hUaW1lXSkgPT0gMSwgJycsDQpDb25jYXQoRm9ybWF0KFtQYXRjaFRpbWVdLCAnaDptbSB0dCAtICcpLCBGb3JtYXQoW1BhdGNoU2NoZWR1bGVFbmRdLCAnaDptbSB0dCcpKQ0KKQIAAXdBcHBsaWNhdGlvbnNDb21wdXRlcixCZWZvcmVQcmludCxMVFh0cmFSZXBvcnRfQmVmb3JlUHJpbnQ7QXBwbGljYXRpb25zQ29tcHV0ZXIsRGF0YVNvdXJjZURlbWFuZGVkLE1lX0RhdGFTb3VyY2VEZW1hbmRlZA==</Resource>\r\n///   </Resources>\r\n/// </XRTypeInfo>\r\nnamespace XtraReportSerialization {\r\n    \r\n    public class ApplicationsComputer : DevExpress.XtraReports.UI.XtraReport {\r\n        private DevExpress.XtraReports.UI.TopMarginBand topMarginBand1;\r\n        private DevExpress.XtraReports.UI.DetailBand detailBandComputer;\r\n        private DevExpress.XtraReports.UI.XRLabel label7;\r\n        private DevExpress.XtraReports.UI.XRLabel label5;\r\n        private DevExpress.XtraReports.UI.XRLabel labelClient;\r\n        private DevExpress.XtraReports.UI.XRLabel label2;\r\n        private DevExpress.XtraReports.UI.XRLabel label4;\r\n        private DevExpress.XtraReports.UI.XRLabel labelLocation;\r\n        private DevExpress.XtraReports.UI.XRLabel label8;\r\n        private DevExpress.XtraReports.UI.XRLabel label14;\r\n        private DevExpress.XtraReports.UI.XRLabel label11;\r\n        private DevExpress.XtraReports.UI.XRLabel labelComputer;\r\n        private DevExpress.XtraReports.UI.XRLabel label6;\r\n        private DevExpress.XtraReports.UI.XRLabel label12;\r\n        private DevExpress.XtraReports.UI.XRLabel label13;\r\n        private DevExpress.XtraReports.UI.XRLabel label10;\r\n        private DevExpress.XtraReports.UI.XRLabel label15;\r\n        private DevExpress.XtraReports.UI.XRLabel label16;\r\n        private DevExpress.XtraReports.UI.BottomMarginBand bottomMarginBand1;\r\n        private DevExpress.XtraReports.UI.PageHeaderBand PageHeader;\r\n        private DevExpress.XtraReports.UI.XRSubreport SubPageHeader;\r\n        private DevExpress.XtraReports.UI.PageFooterBand PageFooter;\r\n        private DevExpress.XtraReports.UI.XRSubreport SubPageFooter;\r\n        private DevExpress.XtraReports.UI.ReportHeaderBand ReportHeader;\r\n        private DevExpress.XtraReports.UI.XRSubreport SubReportHeader;\r\n        private DevExpress.XtraReports.UI.DetailReportBand DetailReport;\r\n        private DevExpress.XtraReports.UI.DetailBand Detail;\r\n        private DevExpress.XtraReports.UI.XRTable table1;\r\n        private DevExpress.XtraReports.UI.XRTableRow tableRow1;\r\n        private DevExpress.XtraReports.UI.XRTableCell tableCell1;\r\n        private DevExpress.XtraReports.UI.XRTableCell tableCell2;\r\n        private DevExpress.XtraReports.UI.XRTableCell tableCell3;\r\n        private DevExpress.XtraReports.UI.XRTableCell tableCell4;\r\n        private DevExpress.XtraReports.UI.GroupHeaderBand GroupHeader1;\r\n        private DevExpress.XtraReports.UI.XRLabel label1;\r\n        private DevExpress.XtraReports.UI.XRTable table2;\r\n        private DevExpress.XtraReports.UI.XRTableRow tableRow2;\r\n        private DevExpress.XtraReports.UI.XRTableCell tableCell5;\r\n        private DevExpress.XtraReports.UI.XRTableCell tableCell6;\r\n        private DevExpress.XtraReports.UI.XRTableCell tableCell7;\r\n        private DevExpress.XtraReports.UI.XRTableCell tableCell8;\r\n        private DevExpress.XtraReports.UI.XRControlStyle ReportTitle;\r\n        private DevExpress.XtraReports.UI.XRControlStyle ReportParameter;\r\n        private DevExpress.XtraReports.UI.XRControlStyle Header1;\r\n        private DevExpress.XtraReports.UI.XRControlStyle LabelCopy;\r\n        private DevExpress.XtraReports.UI.XRControlStyle BodyCopy;\r\n        private DevExpress.XtraReports.UI.XRControlStyle ValueCopy;\r\n        private DevExpress.XtraReports.UI.XRControlStyle Header2;\r\n        private DevExpress.XtraReports.UI.CalculatedField ReportName;\r\n        private DevExpress.XtraReports.UI.CalculatedField ReportDescription;\r\n        private DevExpress.XtraReports.UI.CalculatedField ReportParameters;\r\n        private DevExpress.XtraReports.UI.CalculatedField ClientGroupText;\r\n        private DevExpress.XtraReports.UI.CalculatedField LocationGroupText;\r\n        private DevExpress.XtraReports.UI.CalculatedField PatchScheduleDay;\r\n        private DevExpress.XtraReports.UI.CalculatedField PatchScheduleEnd;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherNetworkCards;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherSensors;\r\n        private DevExpress.XtraReports.UI.CalculatedField SoftwarePrinters;\r\n        private DevExpress.XtraReports.UI.CalculatedField TotalMemoryText;\r\n        private DevExpress.XtraReports.UI.CalculatedField InternalDriveText;\r\n        private DevExpress.XtraReports.UI.CalculatedField InternalDrives;\r\n        private DevExpress.XtraReports.UI.CalculatedField InternalDriveSize;\r\n        private DevExpress.XtraReports.UI.CalculatedField NeedsReview;\r\n        private DevExpress.XtraReports.UI.CalculatedField OpticalDrives;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherDriveText;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherDrives;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherDriveSize;\r\n        private DevExpress.XtraReports.UI.CalculatedField DriveType;\r\n        private DevExpress.XtraReports.UI.CalculatedField InternalDriveUsed;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherDriveUsed;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerLocalAddressText;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerMACText;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerNetworkShares;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerLastStartup;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerLastLogin;\r\n        private DevExpress.XtraReports.UI.CalculatedField MemoryText;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerRAMUsed;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerCPUSpeedText;\r\n        private DevExpress.XtraReports.UI.CalculatedField DrivePercent;\r\n        private DevExpress.XtraReports.UI.CalculatedField DriveUsedText;\r\n        private DevExpress.XtraReports.UI.CalculatedField DriveSizeText;\r\n        private DevExpress.XtraReports.UI.CalculatedField DriveSmartFailedText;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerDriveUsedPct;\r\n        private DevExpress.XtraReports.UI.CalculatedField BookmarkComputer;\r\n        private DevExpress.XtraReports.UI.CalculatedField BookmarkClient;\r\n        private DevExpress.XtraReports.UI.CalculatedField BookmarkLocation;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerRAMUsedPct;\r\n        private System.Resources.ResourceManager _resources;\r\n        private string _resourceString;\r\n        public ApplicationsComputer() {\r\n            this._resourceString = DevExpress.XtraReports.Serialization.XRResourceManager.GetResourceFor(\"XtraReportSerialization.ApplicationsComputer\");\r\n            this.InitializeComponent();\r\n        }\r\n        private System.Resources.ResourceManager resources {\r\n            get {\r\n                if (_resources == null) {\r\n                    this._resources = new DevExpress.XtraReports.Serialization.XRResourceManager(this._resourceString);\r\n                }\r\n                return this._resources;\r\n            }\r\n        }\r\n        private void InitializeComponent() {\r\n            this.topMarginBand1 = new DevExpress.XtraReports.UI.TopMarginBand();\r\n            this.detailBandComputer = new DevExpress.XtraReports.UI.DetailBand();\r\n            this.bottomMarginBand1 = new DevExpress.XtraReports.UI.BottomMarginBand();\r\n            this.PageHeader = new DevExpress.XtraReports.UI.PageHeaderBand();\r\n            this.PageFooter = new DevExpress.XtraReports.UI.PageFooterBand();\r\n            this.ReportHeader = new DevExpress.XtraReports.UI.ReportHeaderBand();\r\n            this.DetailReport = new DevExpress.XtraReports.UI.DetailReportBand();\r\n            this.label7 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label5 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.labelClient = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label2 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label4 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.labelLocation = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label8 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label14 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label11 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.labelComputer = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label6 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label12 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label13 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label10 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label15 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label16 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.SubPageHeader = new DevExpress.XtraReports.UI.XRSubreport();\r\n            this.SubPageFooter = new DevExpress.XtraReports.UI.XRSubreport();\r\n            this.SubReportHeader = new DevExpress.XtraReports.UI.XRSubreport();\r\n            this.Detail = new DevExpress.XtraReports.UI.DetailBand();\r\n            this.GroupHeader1 = new DevExpress.XtraReports.UI.GroupHeaderBand();\r\n            this.table1 = new DevExpress.XtraReports.UI.XRTable();\r\n            this.tableRow1 = new DevExpress.XtraReports.UI.XRTableRow();\r\n            this.tableCell1 = new DevExpress.XtraReports.UI.XRTableCell();\r\n            this.tableCell2 = new DevExpress.XtraReports.UI.XRTableCell();\r\n            this.tableCell3 = new DevExpress.XtraReports.UI.XRTableCell();\r\n            this.tableCell4 = new DevExpress.XtraReports.UI.XRTableCell();\r\n            this.label1 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.table2 = new DevExpress.XtraReports.UI.XRTable();\r\n            this.tableRow2 = new DevExpress.XtraReports.UI.XRTableRow();\r\n            this.tableCell5 = new DevExpress.XtraReports.UI.XRTableCell();\r\n            this.tableCell6 = new DevExpress.XtraReports.UI.XRTableCell();\r\n            this.tableCell7 = new DevExpress.XtraReports.UI.XRTableCell();\r\n            this.tableCell8 = new DevExpress.XtraReports.UI.XRTableCell();\r\n            this.ReportTitle = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.ReportParameter = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.Header1 = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.LabelCopy = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.BodyCopy = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.ValueCopy = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.Header2 = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.ReportName = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ReportDescription = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ReportParameters = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ClientGroupText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.LocationGroupText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.PatchScheduleDay = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.PatchScheduleEnd = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherNetworkCards = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherSensors = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.SoftwarePrinters = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.TotalMemoryText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.InternalDriveText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.InternalDrives = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.InternalDriveSize = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.NeedsReview = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OpticalDrives = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherDriveText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherDrives = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherDriveSize = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DriveType = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.InternalDriveUsed = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherDriveUsed = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerLocalAddressText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerMACText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerNetworkShares = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerLastStartup = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerLastLogin = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.MemoryText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerRAMUsed = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerCPUSpeedText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DrivePercent = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DriveUsedText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DriveSizeText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DriveSmartFailedText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerDriveUsedPct = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.BookmarkComputer = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.BookmarkClient = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.BookmarkLocation = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerRAMUsedPct = new DevExpress.XtraReports.UI.CalculatedField();\r\n            ((System.ComponentModel.ISupportInitialize)(this.table1)).BeginInit();\r\n            ((System.ComponentModel.ISupportInitialize)(this.table2)).BeginInit();\r\n            ((System.ComponentModel.ISupportInitialize)(this)).BeginInit();\r\n            // \r\n            // topMarginBand1\r\n            // \r\n            this.topMarginBand1.HeightF = 50F;\r\n            this.topMarginBand1.Name = \"topMarginBand1\";\r\n            // \r\n            // detailBandComputer\r\n            // \r\n            this.detailBandComputer.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.label7,\r\n                        this.label5,\r\n                        this.labelClient,\r\n                        this.label2,\r\n                        this.label4,\r\n                        this.labelLocation,\r\n                        this.label8,\r\n                        this.label14,\r\n                        this.label11,\r\n                        this.labelComputer,\r\n                        this.label6,\r\n                        this.label12,\r\n                        this.label13,\r\n                        this.label10,\r\n                        this.label15,\r\n                        this.label16});\r\n            this.detailBandComputer.HeightF = 270F;\r\n            this.detailBandComputer.KeepTogether = true;\r\n            this.detailBandComputer.KeepTogetherWithDetailReports = true;\r\n            this.detailBandComputer.Name = \"detailBandComputer\";\r\n            this.detailBandComputer.SortFields.AddRange(new DevExpress.XtraReports.UI.GroupField[] {\r\n                        new DevExpress.XtraReports.UI.GroupField(\"ClientName\", DevExpress.XtraReports.UI.XRColumnSortOrder.Ascending),\r\n                        new DevExpress.XtraReports.UI.GroupField(\"LocationName\", DevExpress.XtraReports.UI.XRColumnSortOrder.Ascending),\r\n                        new DevExpress.XtraReports.UI.GroupField(\"ComputerIsServer\", DevExpress.XtraReports.UI.XRColumnSortOrder.Descending),\r\n                        new DevExpress.XtraReports.UI.GroupField(\"ComputerName\", DevExpress.XtraReports.UI.XRColumnSortOrder.Ascending)});\r\n            // \r\n            // bottomMarginBand1\r\n            // \r\n            this.bottomMarginBand1.HeightF = 50F;\r\n            this.bottomMarginBand1.Name = \"bottomMarginBand1\";\r\n            // \r\n            // PageHeader\r\n            // \r\n            this.PageHeader.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.SubPageHeader});\r\n            this.PageHeader.HeightF = 23F;\r\n            this.PageHeader.Name = \"PageHeader\";\r\n            this.PageHeader.PrintOn = DevExpress.XtraReports.UI.PrintOnPages.NotWithReportHeader;\r\n            // \r\n            // PageFooter\r\n            // \r\n            this.PageFooter.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.SubPageFooter});\r\n            this.PageFooter.HeightF = 22.99999F;\r\n            this.PageFooter.Name = \"PageFooter\";\r\n            this.PageFooter.PrintOn = DevExpress.XtraReports.UI.PrintOnPages.NotWithReportHeader;\r\n            // \r\n            // ReportHeader\r\n            // \r\n            this.ReportHeader.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.SubReportHeader});\r\n            this.ReportHeader.HeightF = 23F;\r\n            this.ReportHeader.Name = \"ReportHeader\";\r\n            this.ReportHeader.PageBreak = DevExpress.XtraReports.UI.PageBreak.AfterBand;\r\n            // \r\n            // DetailReport\r\n            // \r\n            this.DetailReport.Bands.AddRange(new DevExpress.XtraReports.UI.Band[] {\r\n                        this.Detail,\r\n                        this.GroupHeader1});\r\n            this.DetailReport.DataMember = \"Computers.MyQuerySum\";\r\n            this.DetailReport.Level = 0;\r\n            this.DetailReport.Name = \"DetailReport\";\r\n            // \r\n            // label7\r\n            // \r\n            this.label7.LocationFloat = new DevExpress.Utils.PointFloat(0F, 209F);\r\n            this.label7.Name = \"label7\";\r\n            this.label7.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label7.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label7.StyleName = \"LabelCopy\";\r\n            this.label7.Text = \"Asset Tag\";\r\n            // \r\n            // label5\r\n            // \r\n            this.label5.LocationFloat = new DevExpress.Utils.PointFloat(0F, 140F);\r\n            this.label5.Name = \"label5\";\r\n            this.label5.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label5.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label5.StyleName = \"LabelCopy\";\r\n            this.label5.Text = \"Nickname\";\r\n            // \r\n            // labelClient\r\n            // \r\n            this.labelClient.LocationFloat = new DevExpress.Utils.PointFloat(0F, 71.00004F);\r\n            this.labelClient.Name = \"labelClient\";\r\n            this.labelClient.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.labelClient.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.labelClient.StyleName = \"LabelCopy\";\r\n            this.labelClient.Text = \"Client\";\r\n            // \r\n            // label2\r\n            // \r\n            this.label2.LocationFloat = new DevExpress.Utils.PointFloat(0F, 39.9999F);\r\n            this.label2.Name = \"label2\";\r\n            this.label2.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label2.SizeF = new System.Drawing.SizeF(350F, 31F);\r\n            this.label2.StyleName = \"Header1\";\r\n            this.label2.Text = \"Identification\";\r\n            // \r\n            // label4\r\n            // \r\n            this.label4.LocationFloat = new DevExpress.Utils.PointFloat(0F, 116.9999F);\r\n            this.label4.Name = \"label4\";\r\n            this.label4.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label4.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label4.StyleName = \"LabelCopy\";\r\n            this.label4.Text = \"Computer\";\r\n            // \r\n            // labelLocation\r\n            // \r\n            this.labelLocation.BookmarkParent = this.labelClient;\r\n            this.labelLocation.LocationFloat = new DevExpress.Utils.PointFloat(0F, 93.99999F);\r\n            this.labelLocation.Name = \"labelLocation\";\r\n            this.labelLocation.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.labelLocation.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.labelLocation.StyleName = \"LabelCopy\";\r\n            this.labelLocation.Text = \"Location\";\r\n            // \r\n            // label8\r\n            // \r\n            this.label8.LocationFloat = new DevExpress.Utils.PointFloat(0F, 185.9999F);\r\n            this.label8.Name = \"label8\";\r\n            this.label8.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label8.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label8.StyleName = \"LabelCopy\";\r\n            this.label8.Text = \"Last Login\";\r\n            // \r\n            // label14\r\n            // \r\n            this.label14.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerAssetTag\")});\r\n            this.label14.LocationFloat = new DevExpress.Utils.PointFloat(113F, 209F);\r\n            this.label14.Name = \"label14\";\r\n            this.label14.NullValueText = \"No Asset Tag\";\r\n            this.label14.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label14.SizeF = new System.Drawing.SizeF(237F, 22.99998F);\r\n            this.label14.StyleName = \"BodyCopy\";\r\n            this.label14.Text = \"label14\";\r\n            // \r\n            // label11\r\n            // \r\n            this.label11.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerFriendlyName\")});\r\n            this.label11.LocationFloat = new DevExpress.Utils.PointFloat(113F, 140F);\r\n            this.label11.Name = \"label11\";\r\n            this.label11.NullValueText = \"-\";\r\n            this.label11.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label11.SizeF = new System.Drawing.SizeF(237F, 23F);\r\n            this.label11.StyleName = \"BodyCopy\";\r\n            this.label11.Text = \"label11\";\r\n            // \r\n            // labelComputer\r\n            // \r\n            this.labelComputer.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerName\"),\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Bookmark\", null, \"Computers.BookmarkComputer\")});\r\n            this.labelComputer.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.labelComputer.Name = \"labelComputer\";\r\n            this.labelComputer.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.labelComputer.SizeF = new System.Drawing.SizeF(375F, 40F);\r\n            this.labelComputer.StyleName = \"ReportTitle\";\r\n            this.labelComputer.Text = \"labelComputer\";\r\n            // \r\n            // label6\r\n            // \r\n            this.label6.LocationFloat = new DevExpress.Utils.PointFloat(0F, 163F);\r\n            this.label6.Name = \"label6\";\r\n            this.label6.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label6.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label6.StyleName = \"LabelCopy\";\r\n            this.label6.Text = \"Domain\";\r\n            // \r\n            // label12\r\n            // \r\n            this.label12.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerDomain\")});\r\n            this.label12.LocationFloat = new DevExpress.Utils.PointFloat(113F, 163F);\r\n            this.label12.Name = \"label12\";\r\n            this.label12.NullValueText = \"-\";\r\n            this.label12.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label12.SizeF = new System.Drawing.SizeF(237F, 23F);\r\n            this.label12.StyleName = \"BodyCopy\";\r\n            this.label12.Text = \"label12\";\r\n            // \r\n            // label13\r\n            // \r\n            this.label13.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerLastLogin\")});\r\n            this.label13.LocationFloat = new DevExpress.Utils.PointFloat(113F, 185.9999F);\r\n            this.label13.Name = \"label13\";\r\n            this.label13.NullValueText = \"-\";\r\n            this.label13.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label13.SizeF = new System.Drawing.SizeF(237F, 23F);\r\n            this.label13.StyleName = \"BodyCopy\";\r\n            this.label13.Text = \"label13\";\r\n            // \r\n            // label10\r\n            // \r\n            this.label10.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ClientName\")});\r\n            this.label10.LocationFloat = new DevExpress.Utils.PointFloat(113F, 70.99991F);\r\n            this.label10.Name = \"label10\";\r\n            this.label10.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label10.SizeF = new System.Drawing.SizeF(237.0001F, 23F);\r\n            this.label10.StyleName = \"BodyCopy\";\r\n            this.label10.Text = \"label10\";\r\n            // \r\n            // label15\r\n            // \r\n            this.label15.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.LocationName\")});\r\n            this.label15.LocationFloat = new DevExpress.Utils.PointFloat(113F, 93.99986F);\r\n            this.label15.Name = \"label15\";\r\n            this.label15.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label15.SizeF = new System.Drawing.SizeF(237.0001F, 23F);\r\n            this.label15.StyleName = \"BodyCopy\";\r\n            this.label15.Text = \"label15\";\r\n            // \r\n            // label16\r\n            // \r\n            this.label16.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerName\")});\r\n            this.label16.LocationFloat = new DevExpress.Utils.PointFloat(113F, 116.9999F);\r\n            this.label16.Name = \"label16\";\r\n            this.label16.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label16.SizeF = new System.Drawing.SizeF(237.0001F, 23F);\r\n            this.label16.StyleName = \"BodyCopy\";\r\n            this.label16.Text = \"label16\";\r\n            // \r\n            // SubPageHeader\r\n            // \r\n            this.SubPageHeader.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.SubPageHeader.Name = \"SubPageHeader\";\r\n            this.SubPageHeader.ReportSourceUrl = \"SubPageHeader [75383c30-5306-11e4-9ab7-6431502512ea]\";\r\n            this.SubPageHeader.SizeF = new System.Drawing.SizeF(750F, 23F);\r\n            // \r\n            // SubPageFooter\r\n            // \r\n            this.SubPageFooter.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.SubPageFooter.Name = \"SubPageFooter\";\r\n            this.SubPageFooter.ReportSourceUrl = \"SubPageFooter [8bdbe33d-5306-11e4-9ab7-6431502512ea]\";\r\n            this.SubPageFooter.SizeF = new System.Drawing.SizeF(750F, 22.99999F);\r\n            // \r\n            // SubReportHeader\r\n            // \r\n            this.SubReportHeader.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.SubReportHeader.Name = \"SubReportHeader\";\r\n            this.SubReportHeader.ReportSourceUrl = \"SubReportHeader [61c3b74e-5306-11e4-9ab7-6431502512ea]\";\r\n            this.SubReportHeader.SizeF = new System.Drawing.SizeF(750F, 23F);\r\n            // \r\n            // Detail\r\n            // \r\n            this.Detail.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.table1});\r\n            this.Detail.HeightF = 25F;\r\n            this.Detail.Name = \"Detail\";\r\n            // \r\n            // GroupHeader1\r\n            // \r\n            this.GroupHeader1.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.label1,\r\n                        this.table2});\r\n            this.GroupHeader1.HeightF = 100F;\r\n            this.GroupHeader1.Name = \"GroupHeader1\";\r\n            // \r\n            // table1\r\n            // \r\n            this.table1.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.table1.Name = \"table1\";\r\n            this.table1.Rows.AddRange(new DevExpress.XtraReports.UI.XRTableRow[] {\r\n                        this.tableRow1});\r\n            this.table1.SizeF = new System.Drawing.SizeF(750F, 25F);\r\n            // \r\n            // tableRow1\r\n            // \r\n            this.tableRow1.Cells.AddRange(new DevExpress.XtraReports.UI.XRTableCell[] {\r\n                        this.tableCell1,\r\n                        this.tableCell2,\r\n                        this.tableCell3,\r\n                        this.tableCell4});\r\n            this.tableRow1.Name = \"tableRow1\";\r\n            this.tableRow1.Weight = 11.5D;\r\n            // \r\n            // tableCell1\r\n            // \r\n            this.tableCell1.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.MyQuerySum.Application\")});\r\n            this.tableCell1.Name = \"tableCell1\";\r\n            this.tableCell1.Text = \"tableCell1\";\r\n            this.tableCell1.Weight = 0.2857142857142857D;\r\n            // \r\n            // tableCell2\r\n            // \r\n            this.tableCell2.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.MyQuerySum.InstallDate\")});\r\n            this.tableCell2.Name = \"tableCell2\";\r\n            this.tableCell2.Text = \"tableCell2\";\r\n            this.tableCell2.Weight = 0.2857142857142857D;\r\n            // \r\n            // tableCell3\r\n            // \r\n            this.tableCell3.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.MyQuerySum.UninstallDate\")});\r\n            this.tableCell3.Name = \"tableCell3\";\r\n            this.tableCell3.Text = \"tableCell3\";\r\n            this.tableCell3.Weight = 0.2857142857142857D;\r\n            // \r\n            // tableCell4\r\n            // \r\n            this.tableCell4.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.MyQuerySum.InstalledVersion\")});\r\n            this.tableCell4.Name = \"tableCell4\";\r\n            this.tableCell4.Text = \"tableCell4\";\r\n            this.tableCell4.Weight = 0.2857142857142857D;\r\n            // \r\n            // label1\r\n            // \r\n            this.label1.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.label1.Name = \"label1\";\r\n            this.label1.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label1.SizeF = new System.Drawing.SizeF(509.375F, 51.125F);\r\n            this.label1.Text = \"Application Managment\";\r\n            // \r\n            // table2\r\n            // \r\n            this.table2.LocationFloat = new DevExpress.Utils.PointFloat(0F, 65.00002F);\r\n            this.table2.Name = \"table2\";\r\n            this.table2.Rows.AddRange(new DevExpress.XtraReports.UI.XRTableRow[] {\r\n                        this.tableRow2});\r\n            this.table2.SizeF = new System.Drawing.SizeF(750F, 25F);\r\n            // \r\n            // tableRow2\r\n            // \r\n            this.tableRow2.Cells.AddRange(new DevExpress.XtraReports.UI.XRTableCell[] {\r\n                        this.tableCell5,\r\n                        this.tableCell6,\r\n                        this.tableCell7,\r\n                        this.tableCell8});\r\n            this.tableRow2.Name = \"tableRow2\";\r\n            this.tableRow2.Weight = 11.5D;\r\n            // \r\n            // tableCell5\r\n            // \r\n            this.tableCell5.Name = \"tableCell5\";\r\n            this.tableCell5.Text = \"Application\";\r\n            this.tableCell5.Weight = 0.2857142857142857D;\r\n            // \r\n            // tableCell6\r\n            // \r\n            this.tableCell6.Name = \"tableCell6\";\r\n            this.tableCell6.Text = \"Install Date\";\r\n            this.tableCell6.Weight = 0.2857142857142857D;\r\n            // \r\n            // tableCell7\r\n            // \r\n            this.tableCell7.Name = \"tableCell7\";\r\n            this.tableCell7.Text = \"Uninstall Date\";\r\n            this.tableCell7.Weight = 0.2857142857142857D;\r\n            // \r\n            // tableCell8\r\n            // \r\n            this.tableCell8.Name = \"tableCell8\";\r\n            this.tableCell8.Text = \"Installed Version\";\r\n            this.tableCell8.Weight = 0.2857142857142857D;\r\n            // \r\n            // ReportTitle\r\n            // \r\n            this.ReportTitle.Font = new System.Drawing.Font(\"Segoe UI\", 18F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));\r\n            this.ReportTitle.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(107)))), ((int)(((byte)(128)))));\r\n            this.ReportTitle.Name = \"ReportTitle\";\r\n            this.ReportTitle.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleLeft;\r\n            // \r\n            // ReportParameter\r\n            // \r\n            this.ReportParameter.Font = new System.Drawing.Font(\"Segoe UI\", 10F);\r\n            this.ReportParameter.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));\r\n            this.ReportParameter.Name = \"ReportParameter\";\r\n            this.ReportParameter.TextAlignment = DevExpress.XtraPrinting.TextAlignment.TopLeft;\r\n            // \r\n            // Header1\r\n            // \r\n            this.Header1.Font = new System.Drawing.Font(\"Segoe UI Semibold\", 16F);\r\n            this.Header1.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(107)))), ((int)(((byte)(128)))));\r\n            this.Header1.Name = \"Header1\";\r\n            // \r\n            // LabelCopy\r\n            // \r\n            this.LabelCopy.Font = new System.Drawing.Font(\"Segoe UI Semibold\", 9F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));\r\n            this.LabelCopy.Name = \"LabelCopy\";\r\n            this.LabelCopy.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleLeft;\r\n            // \r\n            // BodyCopy\r\n            // \r\n            this.BodyCopy.Font = new System.Drawing.Font(\"Segoe UI\", 9F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));\r\n            this.BodyCopy.Name = \"BodyCopy\";\r\n            this.BodyCopy.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleLeft;\r\n            // \r\n            // ValueCopy\r\n            // \r\n            this.ValueCopy.Font = new System.Drawing.Font(\"Segoe UI\", 20F);\r\n            this.ValueCopy.Name = \"ValueCopy\";\r\n            this.ValueCopy.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.ValueCopy.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleCenter;\r\n            // \r\n            // Header2\r\n            // \r\n            this.Header2.Font = new System.Drawing.Font(\"Segoe UI\", 14F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));\r\n            this.Header2.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(107)))), ((int)(((byte)(128)))));\r\n            this.Header2.Name = \"Header2\";\r\n            this.Header2.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleLeft;\r\n            // \r\n            // ReportName\r\n            // \r\n            this.ReportName.DataMember = \"Computers\";\r\n            this.ReportName.Expression = \"\\\'P4A Applcation Management By Computer\\\'\";\r\n            this.ReportName.Name = \"ReportName\";\r\n            // \r\n            // ReportDescription\r\n            // \r\n            this.ReportDescription.DataMember = \"Computers\";\r\n            this.ReportDescription.Expression = \"\\\'This report displays the managed application list for each agent and the curent \" +\r\n                \"version numbers along with install and uninstall dates.\\\'\";\r\n            this.ReportDescription.Name = \"ReportDescription\";\r\n            // \r\n            // ReportParameters\r\n            // \r\n            this.ReportParameters.DataMember = \"Computers\";\r\n            this.ReportParameters.Expression = \"Format(Now(), \\\'MMMM d, yyyy\\\')\";\r\n            this.ReportParameters.Name = \"ReportParameters\";\r\n            // \r\n            // ClientGroupText\r\n            // \r\n            this.ClientGroupText.DataMember = \"Computers\";\r\n            this.ClientGroupText.Expression = \"[ClientName] + \\\' (\\\' + [ClientID] + \\\')\\\'\";\r\n            this.ClientGroupText.Name = \"ClientGroupText\";\r\n            // \r\n            // LocationGroupText\r\n            // \r\n            this.LocationGroupText.DataMember = \"Computers\";\r\n            this.LocationGroupText.Expression = \"[LocationName] + \\\' (\\\' + [LocationID] + \\\')\\\'\";\r\n            this.LocationGroupText.Name = \"LocationGroupText\";\r\n            // \r\n            // PatchScheduleDay\r\n            // \r\n            this.PatchScheduleDay.DataMember = \"Computers.ComputerHotfixStats\";\r\n            this.PatchScheduleDay.Expression = resources.GetString(\"PatchScheduleDay.Expression\");\r\n            this.PatchScheduleDay.Name = \"PatchScheduleDay\";\r\n            // \r\n            // PatchScheduleEnd\r\n            // \r\n            this.PatchScheduleEnd.DataMember = \"Computers.ComputerHotfixStats\";\r\n            this.PatchScheduleEnd.Expression = \"AddHours([PatchTime], GetDay([PatchTime]))\";\r\n            this.PatchScheduleEnd.Name = \"PatchScheduleEnd\";\r\n            // \r\n            // OtherNetworkCards\r\n            // \r\n            this.OtherNetworkCards.DataMember = \"Computers.ComputerHardware\";\r\n            this.OtherNetworkCards.Expression = \"[TotalNetworkCards] - [WiredNetworkCards] - [WirelessNetworkCards]\";\r\n            this.OtherNetworkCards.Name = \"OtherNetworkCards\";\r\n            // \r\n            // OtherSensors\r\n            // \r\n            this.OtherSensors.DataMember = \"Computers.ComputerHardware\";\r\n            this.OtherSensors.Expression = \"[TotalSensors] - [VoltageSensors] - [TempSensors]\";\r\n            this.OtherSensors.Name = \"OtherSensors\";\r\n            // \r\n            // SoftwarePrinters\r\n            // \r\n            this.SoftwarePrinters.DataMember = \"Computers.ComputerHardware\";\r\n            this.SoftwarePrinters.Expression = \"[TotalPrinters] - [HardwarePrinters]\";\r\n            this.SoftwarePrinters.Name = \"SoftwarePrinters\";\r\n            // \r\n            // TotalMemoryText\r\n            // \r\n            this.TotalMemoryText.DataMember = \"Computers.ComputerHardware\";\r\n            this.TotalMemoryText.Expression = \"Iif([TotalMemory] >= 1024, Concat(Iif([TotalMemory] % 1024 == 0, Round([TotalMemo\" +\r\n                \"ry] / 1024), Round([TotalMemory] / 1024, 2)), \\\' GB\\\'), Concat([TotalMemory], \\\' MB\" +\r\n                \"\\\'))\";\r\n            this.TotalMemoryText.Name = \"TotalMemoryText\";\r\n            // \r\n            // InternalDriveText\r\n            // \r\n            this.InternalDriveText.DataMember = \"Computers.ComputerDrives\";\r\n            this.InternalDriveText.Expression = resources.GetString(\"InternalDriveText.Expression\");\r\n            this.InternalDriveText.Name = \"InternalDriveText\";\r\n            // \r\n            // InternalDrives\r\n            // \r\n            this.InternalDrives.DataMember = \"Computers.ComputerDrives\";\r\n            this.InternalDrives.Expression = \"[][[DriveType] == \\\'Internal\\\'].Count()\";\r\n            this.InternalDrives.Name = \"InternalDrives\";\r\n            // \r\n            // InternalDriveSize\r\n            // \r\n            this.InternalDriveSize.DataMember = \"Computers.ComputerDrives\";\r\n            this.InternalDriveSize.Expression = \"[][[DriveType] == \\\'Internal\\\'].Sum([DriveSize])\";\r\n            this.InternalDriveSize.FieldType = DevExpress.XtraReports.UI.FieldType.Float;\r\n            this.InternalDriveSize.Name = \"InternalDriveSize\";\r\n            // \r\n            // NeedsReview\r\n            // \r\n            this.NeedsReview.DataMember = \"Computers.ComputerDrives\";\r\n            this.NeedsReview.Expression = \"[][[SmartAttributeFailed] > 0].Count()\";\r\n            this.NeedsReview.Name = \"NeedsReview\";\r\n            // \r\n            // OpticalDrives\r\n            // \r\n            this.OpticalDrives.DataMember = \"Computers.ComputerDrives\";\r\n            this.OpticalDrives.Expression = \"[][[DriveType] == \\\'Optical\\\'].Count()\";\r\n            this.OpticalDrives.Name = \"OpticalDrives\";\r\n            // \r\n            // OtherDriveText\r\n            // \r\n            this.OtherDriveText.DataMember = \"Computers.ComputerDrives\";\r\n            this.OtherDriveText.Expression = resources.GetString(\"OtherDriveText.Expression\");\r\n            this.OtherDriveText.Name = \"OtherDriveText\";\r\n            // \r\n            // OtherDrives\r\n            // \r\n            this.OtherDrives.DataMember = \"Computers.ComputerDrives\";\r\n            this.OtherDrives.Expression = \"[][[DriveType] == \\\'Other\\\'].Count()\";\r\n            this.OtherDrives.Name = \"OtherDrives\";\r\n            // \r\n            // OtherDriveSize\r\n            // \r\n            this.OtherDriveSize.DataMember = \"Computers.ComputerDrives\";\r\n            this.OtherDriveSize.Expression = \"[][[DriveType] == \\\'Other\\\'].Sum([DriveSize])\";\r\n            this.OtherDriveSize.FieldType = DevExpress.XtraReports.UI.FieldType.Float;\r\n            this.OtherDriveSize.Name = \"OtherDriveSize\";\r\n            // \r\n            // DriveType\r\n            // \r\n            this.DriveType.DataMember = \"Computers.ComputerDrives\";\r\n            this.DriveType.Expression = resources.GetString(\"DriveType.Expression\");\r\n            this.DriveType.Name = \"DriveType\";\r\n            // \r\n            // InternalDriveUsed\r\n            // \r\n            this.InternalDriveUsed.DataMember = \"Computers.ComputerDrives\";\r\n            this.InternalDriveUsed.Expression = \"[][[DriveType] == \\\'Internal\\\'].Sum([DriveUsed])\";\r\n            this.InternalDriveUsed.FieldType = DevExpress.XtraReports.UI.FieldType.Float;\r\n            this.InternalDriveUsed.Name = \"InternalDriveUsed\";\r\n            // \r\n            // OtherDriveUsed\r\n            // \r\n            this.OtherDriveUsed.DataMember = \"Computers.ComputerDrives\";\r\n            this.OtherDriveUsed.Expression = \"[][[DriveType] == \\\'Other\\\'].Sum([DriveUsed])\";\r\n            this.OtherDriveUsed.FieldType = DevExpress.XtraReports.UI.FieldType.Float;\r\n            this.OtherDriveUsed.Name = \"OtherDriveUsed\";\r\n            // \r\n            // ComputerLocalAddressText\r\n            // \r\n            this.ComputerLocalAddressText.DataMember = \"Computers\";\r\n            this.ComputerLocalAddressText.Expression = \"Iif([ComputerNetworkCards].Exists() And Not IsNullOrEmpty([ComputerNetworkCards.I\" +\r\n                \"PAddress]), [ComputerNetworkCards.IPAddress], [ComputerLocalIP])\";\r\n            this.ComputerLocalAddressText.Name = \"ComputerLocalAddressText\";\r\n            // \r\n            // ComputerMACText\r\n            // \r\n            this.ComputerMACText.DataMember = \"Computers\";\r\n            this.ComputerMACText.Expression = \"Iif([ComputerNetworkCards].Exists() And Not IsNullOrEmpty([ComputerNetworkCards.M\" +\r\n                \"ACAddress]), [ComputerNetworkCards.MACAddress], [ComputerMAC])\";\r\n            this.ComputerMACText.Name = \"ComputerMACText\";\r\n            // \r\n            // ComputerNetworkShares\r\n            // \r\n            this.ComputerNetworkShares.DataMember = \"Computers\";\r\n            this.ComputerNetworkShares.Expression = \"Len([ComputerShares]) - Len(Replace([ComputerShares], \\\':\\\', \\\'\\\')) - (Len([ComputerS\" +\r\n                \"hares]) - Len(Replace([ComputerShares], \\\'$\\\', \\\'\\\')))\";\r\n            this.ComputerNetworkShares.Name = \"ComputerNetworkShares\";\r\n            // \r\n            // ComputerLastStartup\r\n            // \r\n            this.ComputerLastStartup.DataMember = \"Computers\";\r\n            this.ComputerLastStartup.Expression = resources.GetString(\"ComputerLastStartup.Expression\");\r\n            this.ComputerLastStartup.Name = \"ComputerLastStartup\";\r\n            // \r\n            // ComputerLastLogin\r\n            // \r\n            this.ComputerLastLogin.DataMember = \"Computers\";\r\n            this.ComputerLastLogin.Expression = \"Iif(Contains([ComputerUsername], \\\',\\\'), Substring([ComputerUsername], 0, CharIndex\" +\r\n                \"(\\\',\\\', [ComputerUsername])), [ComputerUsername])\";\r\n            this.ComputerLastLogin.Name = \"ComputerLastLogin\";\r\n            // \r\n            // MemoryText\r\n            // \r\n            this.MemoryText.DataMember = \"Computers.ComputerHardware\";\r\n            this.MemoryText.Expression = resources.GetString(\"MemoryText.Expression\");\r\n            this.MemoryText.Name = \"MemoryText\";\r\n            // \r\n            // ComputerRAMUsed\r\n            // \r\n            this.ComputerRAMUsed.DataMember = \"Computers\";\r\n            this.ComputerRAMUsed.Expression = \"Round([ComputerRAMSize] - [ComputerRAMFree], 0)\";\r\n            this.ComputerRAMUsed.FieldType = DevExpress.XtraReports.UI.FieldType.Int16;\r\n            this.ComputerRAMUsed.Name = \"ComputerRAMUsed\";\r\n            // \r\n            // ComputerCPUSpeedText\r\n            // \r\n            this.ComputerCPUSpeedText.DataMember = \"Computers\";\r\n            this.ComputerCPUSpeedText.Expression = resources.GetString(\"ComputerCPUSpeedText.Expression\");\r\n            this.ComputerCPUSpeedText.Name = \"ComputerCPUSpeedText\";\r\n            // \r\n            // DrivePercent\r\n            // \r\n            this.DrivePercent.DataMember = \"Computers.ComputerDrives\";\r\n            this.DrivePercent.Expression = \"Round(Iif([DriveSize] > 0, (ToFloat([DriveUsed]) / ToFloat([DriveSize])) * 100f, \" +\r\n                \"0f))\";\r\n            this.DrivePercent.Name = \"DrivePercent\";\r\n            // \r\n            // DriveUsedText\r\n            // \r\n            this.DriveUsedText.DataMember = \"Computers.ComputerDrives\";\r\n            this.DriveUsedText.Expression = resources.GetString(\"DriveUsedText.Expression\");\r\n            this.DriveUsedText.Name = \"DriveUsedText\";\r\n            // \r\n            // DriveSizeText\r\n            // \r\n            this.DriveSizeText.DataMember = \"Computers.ComputerDrives\";\r\n            this.DriveSizeText.Expression = resources.GetString(\"DriveSizeText.Expression\");\r\n            this.DriveSizeText.Name = \"DriveSizeText\";\r\n            // \r\n            // DriveSmartFailedText\r\n            // \r\n            this.DriveSmartFailedText.DataMember = \"Computers.ComputerDrives\";\r\n            this.DriveSmartFailedText.Expression = \"Iif([SmartAttributeFailed] > 0, \\\'FAIL\\\', \\\'OK\\\')\";\r\n            this.DriveSmartFailedText.Name = \"DriveSmartFailedText\";\r\n            // \r\n            // ComputerDriveUsedPct\r\n            // \r\n            this.ComputerDriveUsedPct.DataMember = \"Computers\";\r\n            this.ComputerDriveUsedPct.Expression = \"Iif([ComputerDrives.InternalDriveSize] <> 0f, Round([ComputerDrives.InternalDrive\" +\r\n                \"Used] / [ComputerDrives.InternalDriveSize] * 100, 0), 0f)\";\r\n            this.ComputerDriveUsedPct.Name = \"ComputerDriveUsedPct\";\r\n            // \r\n            // BookmarkComputer\r\n            // \r\n            this.BookmarkComputer.DataMember = \"Computers\";\r\n            this.BookmarkComputer.Expression = \"Concat([ComputerName], \\\' (\\\', [ComputerID], \\\')\\\')\";\r\n            this.BookmarkComputer.Name = \"BookmarkComputer\";\r\n            // \r\n            // BookmarkClient\r\n            // \r\n            this.BookmarkClient.DataMember = \"Computers\";\r\n            this.BookmarkClient.Expression = \"Concat([ClientName], \\\' (\\\', [ClientID], \\\')\\\')\";\r\n            this.BookmarkClient.Name = \"BookmarkClient\";\r\n            // \r\n            // BookmarkLocation\r\n            // \r\n            this.BookmarkLocation.DataMember = \"Computers\";\r\n            this.BookmarkLocation.Expression = \"Concat([LocationName],  \\\' (\\\', [LocationID], \\\')\\\')\";\r\n            this.BookmarkLocation.Name = \"BookmarkLocation\";\r\n            // \r\n            // ComputerRAMUsedPct\r\n            // \r\n            this.ComputerRAMUsedPct.DataMember = \"Computers\";\r\n            this.ComputerRAMUsedPct.Expression = \"Round(ToFloat([ComputerRAMSize] - [ComputerRAMFree]) / ToFloat([ComputerRAMSize])\" +\r\n                \" * 100,0)\";\r\n            this.ComputerRAMUsedPct.Name = \"ComputerRAMUsedPct\";\r\n            // \r\n            // ApplicationsComputer\r\n            // \r\n            this.Bands.AddRange(new DevExpress.XtraReports.UI.Band[] {\r\n                        this.topMarginBand1,\r\n                        this.detailBandComputer,\r\n                        this.bottomMarginBand1,\r\n                        this.PageHeader,\r\n                        this.PageFooter,\r\n                        this.ReportHeader,\r\n                        this.DetailReport});\r\n            this.Bookmark = \"Computer Base by Computer\";\r\n            this.CalculatedFields.AddRange(new DevExpress.XtraReports.UI.CalculatedField[] {\r\n                        this.ReportName,\r\n                        this.ReportDescription,\r\n                        this.ReportParameters,\r\n                        this.ClientGroupText,\r\n                        this.LocationGroupText,\r\n                        this.PatchScheduleDay,\r\n                        this.PatchScheduleEnd,\r\n                        this.OtherNetworkCards,\r\n                        this.OtherSensors,\r\n                        this.SoftwarePrinters,\r\n                        this.TotalMemoryText,\r\n                        this.InternalDriveText,\r\n                        this.InternalDrives,\r\n                        this.InternalDriveSize,\r\n                        this.NeedsReview,\r\n                        this.OpticalDrives,\r\n                        this.OtherDriveText,\r\n                        this.OtherDrives,\r\n                        this.OtherDriveSize,\r\n                        this.DriveType,\r\n                        this.InternalDriveUsed,\r\n                        this.OtherDriveUsed,\r\n                        this.ComputerLocalAddressText,\r\n                        this.ComputerMACText,\r\n                        this.ComputerNetworkShares,\r\n                        this.ComputerLastStartup,\r\n                        this.ComputerLastLogin,\r\n                        this.MemoryText,\r\n                        this.ComputerRAMUsed,\r\n                        this.ComputerCPUSpeedText,\r\n                        this.DrivePercent,\r\n                        this.DriveUsedText,\r\n                        this.DriveSizeText,\r\n                        this.DriveSmartFailedText,\r\n                        this.ComputerDriveUsedPct,\r\n                        this.BookmarkComputer,\r\n                        this.BookmarkClient,\r\n                        this.BookmarkLocation,\r\n                        this.ComputerRAMUsedPct});\r\n            this.DataMember = \"Computers\";\r\n            this.DisplayName = \"Application management\";\r\n            this.FilterString = null;\r\n            this.Margins = new System.Drawing.Printing.Margins(50, 50, 50, 50);\r\n            this.Name = \"ApplicationsComputer\";\r\n            this.PageHeight = 1100;\r\n            this.PageWidth = 850;\r\n            this.ReportPrintOptions.DetailCountAtDesignTime = 100;\r\n            this.ScriptLanguage = DevExpress.XtraReports.ScriptLanguage.VisualBasic;\r\n            this.StyleSheet.AddRange(new DevExpress.XtraReports.UI.XRControlStyle[] {\r\n                        this.ReportTitle,\r\n                        this.ReportParameter,\r\n                        this.Header1,\r\n                        this.LabelCopy,\r\n                        this.BodyCopy,\r\n                        this.ValueCopy,\r\n                        this.Header2});\r\n            this.Tag = \"1.0.1005.2\";\r\n            this.Version = \"14.2\";\r\n            ((System.ComponentModel.ISupportInitialize)(this.table1)).EndInit();\r\n            ((System.ComponentModel.ISupportInitialize)(this.table2)).EndInit();\r\n            ((System.ComponentModel.ISupportInitialize)(this)).EndInit();\r\n        }\r\n    }\r\n}\r\n',0,'8a3d873e-ae76-4896-b92f-e29be6950910'),(150,'Computer Base (1)',20,'2017-08-04 14:32:50',3,'2017-08-04 14:32:50',3,'This report provides you with a simple starting point for developing custom computer reports. This template features a fully functional computer report with a short summary of computer information to get you started. ','/// <XRTypeInfo>\r\n///   <AssemblyFullName>ReportCenterPlugin, Version=1.1.1005.3, Culture=neutral, PublicKeyToken=null</AssemblyFullName>\r\n///   <AssemblyLocation>C:\\compile\\LabTech\\Projects\\Plugins\\System Additions\\ReportCenter\\trunk\\PluginTesterHost\\bin\\Debug\\ReportCenterPlugin.dll</AssemblyLocation>\r\n///   <TypeName>ReportCenterPlugin.EndUserDesigner.LTXtraReport</TypeName>\r\n///   <Localization>en-US</Localization>\r\n///   <Version>14.2</Version>\r\n///   <References>\r\n///     <Reference Path=\"C:\\compile\\LabTech\\Projects\\Plugins\\System Additions\\ReportCenter\\trunk\\PluginTesterHost\\bin\\Debug\\ReportCenterPlugin.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.VisualBasic\\v4.0_10.0.0.0__b03f5f7f11d50a3a\\Microsoft.VisualBasic.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System\\v4.0_4.0.0.0__b77a5c561934e089\\System.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Configuration\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Configuration.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Xml\\v4.0_4.0.0.0__b77a5c561934e089\\System.Xml.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Data.SqlXml\\v4.0_4.0.0.0__b77a5c561934e089\\System.Data.SqlXml.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Security\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Security.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Core\\v4.0_4.0.0.0__b77a5c561934e089\\System.Core.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Numerics\\v4.0_4.0.0.0__b77a5c561934e089\\System.Numerics.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Windows.Forms\\v4.0_4.0.0.0__b77a5c561934e089\\System.Windows.Forms.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Drawing\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Drawing.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\Accessibility\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\Accessibility.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Deployment\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Deployment.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Runtime.Serialization.Formatters.Soap\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Runtime.Serialization.Formatters.Soap.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Management\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Management.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Configuration.Install\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Configuration.Install.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Runtime.Serialization\\v4.0_4.0.0.0__b77a5c561934e089\\System.Runtime.Serialization.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.ServiceModel.Internals\\v4.0_4.0.0.0__31bf3856ad364e35\\System.ServiceModel.Internals.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\SMDiagnostics\\v4.0_4.0.0.0__b77a5c561934e089\\SMDiagnostics.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.JScript\\v4.0_10.0.0.0__b03f5f7f11d50a3a\\Microsoft.JScript.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Xml.Linq\\v4.0_4.0.0.0__b77a5c561934e089\\System.Xml.Linq.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Runtime.Remoting\\v4.0_4.0.0.0__b77a5c561934e089\\System.Runtime.Remoting.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_64\\System.Web\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Web.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_64\\System.Data\\v4.0_4.0.0.0__b77a5c561934e089\\System.Data.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_64\\System.Transactions\\v4.0_4.0.0.0__b77a5c561934e089\\System.Transactions.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_64\\System.EnterpriseServices\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.EnterpriseServices.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.DirectoryServices\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.DirectoryServices.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Web.RegularExpressions\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Web.RegularExpressions.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Design\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Design.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_64\\System.Data.OracleClient\\v4.0_4.0.0.0__b77a5c561934e089\\System.Data.OracleClient.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Drawing.Design\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Drawing.Design.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Web.ApplicationServices\\v4.0_4.0.0.0__31bf3856ad364e35\\System.Web.ApplicationServices.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.ComponentModel.DataAnnotations\\v4.0_4.0.0.0__31bf3856ad364e35\\System.ComponentModel.DataAnnotations.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.DirectoryServices.Protocols\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.DirectoryServices.Protocols.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Runtime.Caching\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Runtime.Caching.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.ServiceProcess\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.ServiceProcess.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Web.Services\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\System.Web.Services.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.Build.Utilities.v4.0\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\Microsoft.Build.Utilities.v4.0.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.Build.Framework\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\Microsoft.Build.Framework.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Xaml\\v4.0_4.0.0.0__b77a5c561934e089\\System.Xaml.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\Microsoft.Build.Tasks.v4.0\\v4.0_4.0.0.0__b03f5f7f11d50a3a\\Microsoft.Build.Tasks.v4.0.dll\" />\r\n///     <Reference Path=\"C:\\compile\\LabTech\\Projects\\Plugins\\System Additions\\ReportCenter\\trunk\\PluginTesterHost\\bin\\Debug\\Interfaces.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraScheduler.v14.2.Core\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraScheduler.v14.2.Core.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraReports.v14.2.Extensions\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraReports.v14.2.Extensions.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.Utils.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.Utils.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\UIAutomationClient\\v4.0_4.0.0.0__31bf3856ad364e35\\UIAutomationClient.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\WindowsBase\\v4.0_4.0.0.0__31bf3856ad364e35\\WindowsBase.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\UIAutomationTypes\\v4.0_4.0.0.0__31bf3856ad364e35\\UIAutomationTypes.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\UIAutomationProvider\\v4.0_4.0.0.0__31bf3856ad364e35\\UIAutomationProvider.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_64\\PresentationCore\\v4.0_4.0.0.0__31bf3856ad364e35\\PresentationCore.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Windows.Input.Manipulations\\v4.0_4.0.0.0__b77a5c561934e089\\System.Windows.Input.Manipulations.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.Utils.v14.2.UI\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.Utils.v14.2.UI.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraBars.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraBars.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraEditors.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraEditors.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\System.Data.Linq\\v4.0_4.0.0.0__b77a5c561934e089\\System.Data.Linq.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraTreeList.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraTreeList.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraRichEdit.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraRichEdit.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraPrinting.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraPrinting.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraVerticalGrid.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraVerticalGrid.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraCharts.v14.2.Extensions\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraCharts.v14.2.Extensions.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraCharts.v14.2.Wizard\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraCharts.v14.2.Wizard.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraNavBar.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraNavBar.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraPivotGrid.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraPivotGrid.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.CodeParser.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.CodeParser.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.DataAccess.v14.2.UI\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.DataAccess.v14.2.UI.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraWizard.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraWizard.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraGrid.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraGrid.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraLayout.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraLayout.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraScheduler.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraScheduler.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraRichEdit.v14.2.Extensions\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraRichEdit.v14.2.Extensions.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.XtraSpellChecker.v14.2\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.XtraSpellChecker.v14.2.dll\" />\r\n///     <Reference Path=\"C:\\Windows\\Microsoft.Net\\assembly\\GAC_MSIL\\DevExpress.SpellChecker.v14.2.Core\\v4.0_14.2.7.0__b88d1754d700e49a\\DevExpress.SpellChecker.v14.2.Core.dll\" />\r\n///   </References>\r\n///   <Resources>\r\n///     <Resource Name=\"XtraReportSerialization.BaseComputer\">\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// X3hyX2NvbXB1dGVycyIgRGF0YVR5cGU9IlN5c3RlbS5TdHJpbmciPkNsaWVudE5hbWU8L0NvbHVtbj48Q29sdW1uIFRhYmxlPSJ2X3hyX2NvbXB1dGVycyIgRGF0YVR5cGU9IlN5c3RlbS5TdHJpbmciPkNsaWVudENvbXBhbnk8L0NvbHVtbj48Q29sdW1uIFRhYmxlPSJ2X3hyX2NvbXB1dGVycyIgRGF0YVR5cGU9IlN5c3RlbS5TdHJpbmciPkNsaWVudEFyZWE8L0NvbHVtbj48Q29sdW1uIFRhYmxlPSJ2X3hyX2NvbXB1dGVycyIgRGF0YVR5cGU9IlN5c3RlbS5JbnQzMiI+TG9jYXRpb25JRDwvQ29sdW1uPjxDb2x1bW4gVGFibGU9InZfeHJfY29tcHV0ZXJzIiBEYXRhVHlwZT0iU3lzdGVtLlN0cmluZyI+TG9jYXRpb25OYW1lPC9Db2x1bW4+PENvbHVtbiBUYWJs\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// 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\r\n/// NiwgUm91bmQoW090aGVyRHJpdmVVc2VkXS8xMDI0Zi8xMDI0ZiwgMikgKyAnIFRCJywgSWlmKFtPdGhlckRyaXZlVXNlZF0gPiAxMDI0MCwgUm91bmQoW090aGVyRHJpdmVVc2VkXS8xMDI0ZiwgMCkgKyAnIEdCJywgSWlmKFtPdGhlckRyaXZlVXNlZF0gPiAxMDI0LCBSb3VuZChbT3RoZXJEcml2ZVVzZWRdLzEwMjRmLCAyKSArICcgR0InLCBSb3VuZChbT3RoZXJEcml2ZVVzZWRdLCAwKSArICcgTUInKSkpLA0KJyAvICcsIA0KSWlmKFtPdGhlckRyaXZlU2l6ZV0gPiAxMDQ4NTc2LCBSb3VuZChbT3RoZXJEcml2ZVNpemVdLzEwMjRmLzEwMjRmLCAyKSArICcgVEInLCBJaWYoW090aGVyRHJpdmVTaXplXSA+IDEwMjQwLCBSb3VuZChbT3RoZXJEcml2ZVNpemVd\r\n/// 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\r\n/// 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\r\n/// AWdCYXNlQ29tcHV0ZXIsRGF0YVNvdXJjZURlbWFuZGVkLE1lX0RhdGFTb3VyY2VEZW1hbmRlZDtCYXNlQ29tcHV0ZXIsQmVmb3JlUHJpbnQsTFRYdHJhUmVwb3J0X0JlZm9yZVByaW50</Resource>\r\n///   </Resources>\r\n/// </XRTypeInfo>\r\nnamespace XtraReportSerialization {\r\n    \r\n    public class BaseComputer : DevExpress.XtraReports.UI.XtraReport {\r\n        private DevExpress.XtraReports.UI.TopMarginBand topMarginBand1;\r\n        private DevExpress.XtraReports.UI.DetailBand detailBandComputer;\r\n        private DevExpress.XtraReports.UI.XRLabel label7;\r\n        private DevExpress.XtraReports.UI.XRLabel label5;\r\n        private DevExpress.XtraReports.UI.XRLabel labelClient;\r\n        private DevExpress.XtraReports.UI.XRLabel label2;\r\n        private DevExpress.XtraReports.UI.XRLabel label4;\r\n        private DevExpress.XtraReports.UI.XRLabel labelLocation;\r\n        private DevExpress.XtraReports.UI.XRLabel label8;\r\n        private DevExpress.XtraReports.UI.XRLabel label14;\r\n        private DevExpress.XtraReports.UI.XRLabel label11;\r\n        private DevExpress.XtraReports.UI.XRLabel labelComputer;\r\n        private DevExpress.XtraReports.UI.XRLabel label6;\r\n        private DevExpress.XtraReports.UI.XRLabel label12;\r\n        private DevExpress.XtraReports.UI.XRLabel label13;\r\n        private DevExpress.XtraReports.UI.XRLabel label10;\r\n        private DevExpress.XtraReports.UI.XRLabel label15;\r\n        private DevExpress.XtraReports.UI.XRLabel label16;\r\n        private DevExpress.XtraReports.UI.BottomMarginBand bottomMarginBand1;\r\n        private DevExpress.XtraReports.UI.PageHeaderBand PageHeader;\r\n        private DevExpress.XtraReports.UI.XRSubreport SubPageHeader;\r\n        private DevExpress.XtraReports.UI.PageFooterBand PageFooter;\r\n        private DevExpress.XtraReports.UI.XRSubreport SubPageFooter;\r\n        private DevExpress.XtraReports.UI.ReportHeaderBand ReportHeader;\r\n        private DevExpress.XtraReports.UI.XRSubreport SubReportHeader;\r\n        private DevExpress.XtraReports.UI.XRControlStyle ReportTitle;\r\n        private DevExpress.XtraReports.UI.XRControlStyle ReportParameter;\r\n        private DevExpress.XtraReports.UI.XRControlStyle Header1;\r\n        private DevExpress.XtraReports.UI.XRControlStyle LabelCopy;\r\n        private DevExpress.XtraReports.UI.XRControlStyle BodyCopy;\r\n        private DevExpress.XtraReports.UI.XRControlStyle ValueCopy;\r\n        private DevExpress.XtraReports.UI.XRControlStyle Header2;\r\n        private DevExpress.XtraReports.UI.CalculatedField ReportName;\r\n        private DevExpress.XtraReports.UI.CalculatedField ReportDescription;\r\n        private DevExpress.XtraReports.UI.CalculatedField ReportParameters;\r\n        private DevExpress.XtraReports.UI.CalculatedField ClientGroupText;\r\n        private DevExpress.XtraReports.UI.CalculatedField LocationGroupText;\r\n        private DevExpress.XtraReports.UI.CalculatedField PatchScheduleDay;\r\n        private DevExpress.XtraReports.UI.CalculatedField PatchScheduleEnd;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherNetworkCards;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherSensors;\r\n        private DevExpress.XtraReports.UI.CalculatedField SoftwarePrinters;\r\n        private DevExpress.XtraReports.UI.CalculatedField TotalMemoryText;\r\n        private DevExpress.XtraReports.UI.CalculatedField InternalDriveText;\r\n        private DevExpress.XtraReports.UI.CalculatedField InternalDrives;\r\n        private DevExpress.XtraReports.UI.CalculatedField InternalDriveSize;\r\n        private DevExpress.XtraReports.UI.CalculatedField NeedsReview;\r\n        private DevExpress.XtraReports.UI.CalculatedField OpticalDrives;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherDriveText;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherDrives;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherDriveSize;\r\n        private DevExpress.XtraReports.UI.CalculatedField DriveType;\r\n        private DevExpress.XtraReports.UI.CalculatedField InternalDriveUsed;\r\n        private DevExpress.XtraReports.UI.CalculatedField OtherDriveUsed;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerLocalAddressText;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerMACText;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerNetworkShares;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerLastStartup;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerLastLogin;\r\n        private DevExpress.XtraReports.UI.CalculatedField MemoryText;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerRAMUsed;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerCPUSpeedText;\r\n        private DevExpress.XtraReports.UI.CalculatedField DrivePercent;\r\n        private DevExpress.XtraReports.UI.CalculatedField DriveUsedText;\r\n        private DevExpress.XtraReports.UI.CalculatedField DriveSizeText;\r\n        private DevExpress.XtraReports.UI.CalculatedField DriveSmartFailedText;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerDriveUsedPct;\r\n        private DevExpress.XtraReports.UI.CalculatedField BookmarkComputer;\r\n        private DevExpress.XtraReports.UI.CalculatedField BookmarkClient;\r\n        private DevExpress.XtraReports.UI.CalculatedField BookmarkLocation;\r\n        private DevExpress.XtraReports.UI.CalculatedField ComputerRAMUsedPct;\r\n        private System.Resources.ResourceManager _resources;\r\n        private string _resourceString;\r\n        public BaseComputer() {\r\n            this._resourceString = DevExpress.XtraReports.Serialization.XRResourceManager.GetResourceFor(\"XtraReportSerialization.BaseComputer\");\r\n            this.InitializeComponent();\r\n        }\r\n        private System.Resources.ResourceManager resources {\r\n            get {\r\n                if (_resources == null) {\r\n                    this._resources = new DevExpress.XtraReports.Serialization.XRResourceManager(this._resourceString);\r\n                }\r\n                return this._resources;\r\n            }\r\n        }\r\n        private void InitializeComponent() {\r\n            this.topMarginBand1 = new DevExpress.XtraReports.UI.TopMarginBand();\r\n            this.detailBandComputer = new DevExpress.XtraReports.UI.DetailBand();\r\n            this.bottomMarginBand1 = new DevExpress.XtraReports.UI.BottomMarginBand();\r\n            this.PageHeader = new DevExpress.XtraReports.UI.PageHeaderBand();\r\n            this.PageFooter = new DevExpress.XtraReports.UI.PageFooterBand();\r\n            this.ReportHeader = new DevExpress.XtraReports.UI.ReportHeaderBand();\r\n            this.label7 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label5 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.labelClient = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label2 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label4 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.labelLocation = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label8 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label14 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label11 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.labelComputer = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label6 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label12 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label13 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label10 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label15 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.label16 = new DevExpress.XtraReports.UI.XRLabel();\r\n            this.SubPageHeader = new DevExpress.XtraReports.UI.XRSubreport();\r\n            this.SubPageFooter = new DevExpress.XtraReports.UI.XRSubreport();\r\n            this.SubReportHeader = new DevExpress.XtraReports.UI.XRSubreport();\r\n            this.ReportTitle = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.ReportParameter = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.Header1 = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.LabelCopy = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.BodyCopy = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.ValueCopy = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.Header2 = new DevExpress.XtraReports.UI.XRControlStyle();\r\n            this.ReportName = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ReportDescription = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ReportParameters = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ClientGroupText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.LocationGroupText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.PatchScheduleDay = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.PatchScheduleEnd = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherNetworkCards = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherSensors = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.SoftwarePrinters = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.TotalMemoryText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.InternalDriveText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.InternalDrives = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.InternalDriveSize = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.NeedsReview = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OpticalDrives = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherDriveText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherDrives = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherDriveSize = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DriveType = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.InternalDriveUsed = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.OtherDriveUsed = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerLocalAddressText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerMACText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerNetworkShares = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerLastStartup = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerLastLogin = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.MemoryText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerRAMUsed = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerCPUSpeedText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DrivePercent = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DriveUsedText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DriveSizeText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.DriveSmartFailedText = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerDriveUsedPct = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.BookmarkComputer = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.BookmarkClient = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.BookmarkLocation = new DevExpress.XtraReports.UI.CalculatedField();\r\n            this.ComputerRAMUsedPct = new DevExpress.XtraReports.UI.CalculatedField();\r\n            ((System.ComponentModel.ISupportInitialize)(this)).BeginInit();\r\n            // \r\n            // topMarginBand1\r\n            // \r\n            this.topMarginBand1.HeightF = 50F;\r\n            this.topMarginBand1.Name = \"topMarginBand1\";\r\n            // \r\n            // detailBandComputer\r\n            // \r\n            this.detailBandComputer.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.label7,\r\n                        this.label5,\r\n                        this.labelClient,\r\n                        this.label2,\r\n                        this.label4,\r\n                        this.labelLocation,\r\n                        this.label8,\r\n                        this.label14,\r\n                        this.label11,\r\n                        this.labelComputer,\r\n                        this.label6,\r\n                        this.label12,\r\n                        this.label13,\r\n                        this.label10,\r\n                        this.label15,\r\n                        this.label16});\r\n            this.detailBandComputer.HeightF = 270F;\r\n            this.detailBandComputer.KeepTogether = true;\r\n            this.detailBandComputer.KeepTogetherWithDetailReports = true;\r\n            this.detailBandComputer.Name = \"detailBandComputer\";\r\n            this.detailBandComputer.SortFields.AddRange(new DevExpress.XtraReports.UI.GroupField[] {\r\n                        new DevExpress.XtraReports.UI.GroupField(\"ClientName\", DevExpress.XtraReports.UI.XRColumnSortOrder.Ascending),\r\n                        new DevExpress.XtraReports.UI.GroupField(\"LocationName\", DevExpress.XtraReports.UI.XRColumnSortOrder.Ascending),\r\n                        new DevExpress.XtraReports.UI.GroupField(\"ComputerIsServer\", DevExpress.XtraReports.UI.XRColumnSortOrder.Descending),\r\n                        new DevExpress.XtraReports.UI.GroupField(\"ComputerName\", DevExpress.XtraReports.UI.XRColumnSortOrder.Ascending)});\r\n            // \r\n            // bottomMarginBand1\r\n            // \r\n            this.bottomMarginBand1.HeightF = 50F;\r\n            this.bottomMarginBand1.Name = \"bottomMarginBand1\";\r\n            // \r\n            // PageHeader\r\n            // \r\n            this.PageHeader.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.SubPageHeader});\r\n            this.PageHeader.HeightF = 23F;\r\n            this.PageHeader.Name = \"PageHeader\";\r\n            this.PageHeader.PrintOn = DevExpress.XtraReports.UI.PrintOnPages.NotWithReportHeader;\r\n            // \r\n            // PageFooter\r\n            // \r\n            this.PageFooter.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.SubPageFooter});\r\n            this.PageFooter.HeightF = 22.99999F;\r\n            this.PageFooter.Name = \"PageFooter\";\r\n            this.PageFooter.PrintOn = DevExpress.XtraReports.UI.PrintOnPages.NotWithReportHeader;\r\n            // \r\n            // ReportHeader\r\n            // \r\n            this.ReportHeader.Controls.AddRange(new DevExpress.XtraReports.UI.XRControl[] {\r\n                        this.SubReportHeader});\r\n            this.ReportHeader.HeightF = 23F;\r\n            this.ReportHeader.Name = \"ReportHeader\";\r\n            this.ReportHeader.PageBreak = DevExpress.XtraReports.UI.PageBreak.AfterBand;\r\n            // \r\n            // label7\r\n            // \r\n            this.label7.LocationFloat = new DevExpress.Utils.PointFloat(0F, 209F);\r\n            this.label7.Name = \"label7\";\r\n            this.label7.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label7.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label7.StyleName = \"LabelCopy\";\r\n            this.label7.Text = \"Asset Tag\";\r\n            // \r\n            // label5\r\n            // \r\n            this.label5.LocationFloat = new DevExpress.Utils.PointFloat(0F, 140F);\r\n            this.label5.Name = \"label5\";\r\n            this.label5.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label5.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label5.StyleName = \"LabelCopy\";\r\n            this.label5.Text = \"Nickname\";\r\n            // \r\n            // labelClient\r\n            // \r\n            this.labelClient.LocationFloat = new DevExpress.Utils.PointFloat(0F, 71.00004F);\r\n            this.labelClient.Name = \"labelClient\";\r\n            this.labelClient.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.labelClient.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.labelClient.StyleName = \"LabelCopy\";\r\n            this.labelClient.Text = \"Client\";\r\n            // \r\n            // label2\r\n            // \r\n            this.label2.LocationFloat = new DevExpress.Utils.PointFloat(0F, 39.9999F);\r\n            this.label2.Name = \"label2\";\r\n            this.label2.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label2.SizeF = new System.Drawing.SizeF(350F, 31F);\r\n            this.label2.StyleName = \"Header1\";\r\n            this.label2.Text = \"Identification\";\r\n            // \r\n            // label4\r\n            // \r\n            this.label4.LocationFloat = new DevExpress.Utils.PointFloat(0F, 116.9999F);\r\n            this.label4.Name = \"label4\";\r\n            this.label4.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label4.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label4.StyleName = \"LabelCopy\";\r\n            this.label4.Text = \"Computer\";\r\n            // \r\n            // labelLocation\r\n            // \r\n            this.labelLocation.BookmarkParent = this.labelClient;\r\n            this.labelLocation.LocationFloat = new DevExpress.Utils.PointFloat(0F, 93.99999F);\r\n            this.labelLocation.Name = \"labelLocation\";\r\n            this.labelLocation.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.labelLocation.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.labelLocation.StyleName = \"LabelCopy\";\r\n            this.labelLocation.Text = \"Location\";\r\n            // \r\n            // label8\r\n            // \r\n            this.label8.LocationFloat = new DevExpress.Utils.PointFloat(0F, 185.9999F);\r\n            this.label8.Name = \"label8\";\r\n            this.label8.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label8.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label8.StyleName = \"LabelCopy\";\r\n            this.label8.Text = \"Last Login\";\r\n            // \r\n            // label14\r\n            // \r\n            this.label14.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerAssetTag\")});\r\n            this.label14.LocationFloat = new DevExpress.Utils.PointFloat(113F, 209F);\r\n            this.label14.Name = \"label14\";\r\n            this.label14.NullValueText = \"No Asset Tag\";\r\n            this.label14.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label14.SizeF = new System.Drawing.SizeF(237F, 22.99998F);\r\n            this.label14.StyleName = \"BodyCopy\";\r\n            this.label14.Text = \"label14\";\r\n            // \r\n            // label11\r\n            // \r\n            this.label11.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerFriendlyName\")});\r\n            this.label11.LocationFloat = new DevExpress.Utils.PointFloat(113F, 140F);\r\n            this.label11.Name = \"label11\";\r\n            this.label11.NullValueText = \"-\";\r\n            this.label11.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label11.SizeF = new System.Drawing.SizeF(237F, 23F);\r\n            this.label11.StyleName = \"BodyCopy\";\r\n            this.label11.Text = \"label11\";\r\n            // \r\n            // labelComputer\r\n            // \r\n            this.labelComputer.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerName\"),\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Bookmark\", null, \"Computers.BookmarkComputer\")});\r\n            this.labelComputer.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.labelComputer.Name = \"labelComputer\";\r\n            this.labelComputer.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.labelComputer.SizeF = new System.Drawing.SizeF(375F, 40F);\r\n            this.labelComputer.StyleName = \"ReportTitle\";\r\n            this.labelComputer.Text = \"labelComputer\";\r\n            // \r\n            // label6\r\n            // \r\n            this.label6.LocationFloat = new DevExpress.Utils.PointFloat(0F, 163F);\r\n            this.label6.Name = \"label6\";\r\n            this.label6.Padding = new DevExpress.XtraPrinting.PaddingInfo(10, 2, 0, 0, 100F);\r\n            this.label6.SizeF = new System.Drawing.SizeF(113F, 23F);\r\n            this.label6.StyleName = \"LabelCopy\";\r\n            this.label6.Text = \"Domain\";\r\n            // \r\n            // label12\r\n            // \r\n            this.label12.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerDomain\")});\r\n            this.label12.LocationFloat = new DevExpress.Utils.PointFloat(113F, 163F);\r\n            this.label12.Name = \"label12\";\r\n            this.label12.NullValueText = \"-\";\r\n            this.label12.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label12.SizeF = new System.Drawing.SizeF(237F, 23F);\r\n            this.label12.StyleName = \"BodyCopy\";\r\n            this.label12.Text = \"label12\";\r\n            // \r\n            // label13\r\n            // \r\n            this.label13.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerLastLogin\")});\r\n            this.label13.LocationFloat = new DevExpress.Utils.PointFloat(113F, 185.9999F);\r\n            this.label13.Name = \"label13\";\r\n            this.label13.NullValueText = \"-\";\r\n            this.label13.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label13.SizeF = new System.Drawing.SizeF(237F, 23F);\r\n            this.label13.StyleName = \"BodyCopy\";\r\n            this.label13.Text = \"label13\";\r\n            // \r\n            // label10\r\n            // \r\n            this.label10.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ClientName\")});\r\n            this.label10.LocationFloat = new DevExpress.Utils.PointFloat(113F, 70.99991F);\r\n            this.label10.Name = \"label10\";\r\n            this.label10.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label10.SizeF = new System.Drawing.SizeF(237.0001F, 23F);\r\n            this.label10.StyleName = \"BodyCopy\";\r\n            this.label10.Text = \"label10\";\r\n            // \r\n            // label15\r\n            // \r\n            this.label15.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.LocationName\")});\r\n            this.label15.LocationFloat = new DevExpress.Utils.PointFloat(113F, 93.99986F);\r\n            this.label15.Name = \"label15\";\r\n            this.label15.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label15.SizeF = new System.Drawing.SizeF(237.0001F, 23F);\r\n            this.label15.StyleName = \"BodyCopy\";\r\n            this.label15.Text = \"label15\";\r\n            // \r\n            // label16\r\n            // \r\n            this.label16.DataBindings.AddRange(new DevExpress.XtraReports.UI.XRBinding[] {\r\n                        new DevExpress.XtraReports.UI.XRBinding(\"Text\", null, \"Computers.ComputerName\")});\r\n            this.label16.LocationFloat = new DevExpress.Utils.PointFloat(113F, 116.9999F);\r\n            this.label16.Name = \"label16\";\r\n            this.label16.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.label16.SizeF = new System.Drawing.SizeF(237.0001F, 23F);\r\n            this.label16.StyleName = \"BodyCopy\";\r\n            this.label16.Text = \"label16\";\r\n            // \r\n            // SubPageHeader\r\n            // \r\n            this.SubPageHeader.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.SubPageHeader.Name = \"SubPageHeader\";\r\n            this.SubPageHeader.ReportSourceUrl = \"SubPageHeader [75383c30-5306-11e4-9ab7-6431502512ea]\";\r\n            this.SubPageHeader.SizeF = new System.Drawing.SizeF(750F, 23F);\r\n            // \r\n            // SubPageFooter\r\n            // \r\n            this.SubPageFooter.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.SubPageFooter.Name = \"SubPageFooter\";\r\n            this.SubPageFooter.ReportSourceUrl = \"SubPageFooter [8bdbe33d-5306-11e4-9ab7-6431502512ea]\";\r\n            this.SubPageFooter.SizeF = new System.Drawing.SizeF(750F, 22.99999F);\r\n            // \r\n            // SubReportHeader\r\n            // \r\n            this.SubReportHeader.LocationFloat = new DevExpress.Utils.PointFloat(0F, 0F);\r\n            this.SubReportHeader.Name = \"SubReportHeader\";\r\n            this.SubReportHeader.ReportSourceUrl = \"SubReportHeader [61c3b74e-5306-11e4-9ab7-6431502512ea]\";\r\n            this.SubReportHeader.SizeF = new System.Drawing.SizeF(750F, 23F);\r\n            // \r\n            // ReportTitle\r\n            // \r\n            this.ReportTitle.Font = new System.Drawing.Font(\"Segoe UI\", 18F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));\r\n            this.ReportTitle.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(107)))), ((int)(((byte)(128)))));\r\n            this.ReportTitle.Name = \"ReportTitle\";\r\n            this.ReportTitle.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleLeft;\r\n            // \r\n            // ReportParameter\r\n            // \r\n            this.ReportParameter.Font = new System.Drawing.Font(\"Segoe UI\", 10F);\r\n            this.ReportParameter.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));\r\n            this.ReportParameter.Name = \"ReportParameter\";\r\n            this.ReportParameter.TextAlignment = DevExpress.XtraPrinting.TextAlignment.TopLeft;\r\n            // \r\n            // Header1\r\n            // \r\n            this.Header1.Font = new System.Drawing.Font(\"Segoe UI Semibold\", 16F);\r\n            this.Header1.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(107)))), ((int)(((byte)(128)))));\r\n            this.Header1.Name = \"Header1\";\r\n            // \r\n            // LabelCopy\r\n            // \r\n            this.LabelCopy.Font = new System.Drawing.Font(\"Segoe UI Semibold\", 9F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));\r\n            this.LabelCopy.Name = \"LabelCopy\";\r\n            this.LabelCopy.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleLeft;\r\n            // \r\n            // BodyCopy\r\n            // \r\n            this.BodyCopy.Font = new System.Drawing.Font(\"Segoe UI\", 9F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));\r\n            this.BodyCopy.Name = \"BodyCopy\";\r\n            this.BodyCopy.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleLeft;\r\n            // \r\n            // ValueCopy\r\n            // \r\n            this.ValueCopy.Font = new System.Drawing.Font(\"Segoe UI\", 20F);\r\n            this.ValueCopy.Name = \"ValueCopy\";\r\n            this.ValueCopy.Padding = new DevExpress.XtraPrinting.PaddingInfo(2, 2, 0, 0, 100F);\r\n            this.ValueCopy.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleCenter;\r\n            // \r\n            // Header2\r\n            // \r\n            this.Header2.Font = new System.Drawing.Font(\"Segoe UI\", 14F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));\r\n            this.Header2.ForeColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(107)))), ((int)(((byte)(128)))));\r\n            this.Header2.Name = \"Header2\";\r\n            this.Header2.TextAlignment = DevExpress.XtraPrinting.TextAlignment.MiddleLeft;\r\n            // \r\n            // ReportName\r\n            // \r\n            this.ReportName.DataMember = \"Computers\";\r\n            this.ReportName.Expression = \"\\\'Computer Report Template\\\'\";\r\n            this.ReportName.Name = \"ReportName\";\r\n            // \r\n            // ReportDescription\r\n            // \r\n            this.ReportDescription.DataMember = \"Computers\";\r\n            this.ReportDescription.Expression = \"\\\'Computer report description here\\\'\";\r\n            this.ReportDescription.Name = \"ReportDescription\";\r\n            // \r\n            // ReportParameters\r\n            // \r\n            this.ReportParameters.DataMember = \"Computers\";\r\n            this.ReportParameters.Expression = \"Format(Now(), \\\'MMMM d, yyyy\\\')\";\r\n            this.ReportParameters.Name = \"ReportParameters\";\r\n            // \r\n            // ClientGroupText\r\n            // \r\n            this.ClientGroupText.DataMember = \"Computers\";\r\n            this.ClientGroupText.Expression = \"[ClientName] + \\\' (\\\' + [ClientID] + \\\')\\\'\";\r\n            this.ClientGroupText.Name = \"ClientGroupText\";\r\n            // \r\n            // LocationGroupText\r\n            // \r\n            this.LocationGroupText.DataMember = \"Computers\";\r\n            this.LocationGroupText.Expression = \"[LocationName] + \\\' (\\\' + [LocationID] + \\\')\\\'\";\r\n            this.LocationGroupText.Name = \"LocationGroupText\";\r\n            // \r\n            // PatchScheduleDay\r\n            // \r\n            this.PatchScheduleDay.DataMember = \"Computers.ComputerHotfixStats\";\r\n            this.PatchScheduleDay.Expression = resources.GetString(\"PatchScheduleDay.Expression\");\r\n            this.PatchScheduleDay.Name = \"PatchScheduleDay\";\r\n            // \r\n            // PatchScheduleEnd\r\n            // \r\n            this.PatchScheduleEnd.DataMember = \"Computers.ComputerHotfixStats\";\r\n            this.PatchScheduleEnd.Expression = \"AddHours([PatchTime], GetDay([PatchTime]))\";\r\n            this.PatchScheduleEnd.Name = \"PatchScheduleEnd\";\r\n            // \r\n            // OtherNetworkCards\r\n            // \r\n            this.OtherNetworkCards.DataMember = \"Computers.ComputerHardware\";\r\n            this.OtherNetworkCards.Expression = \"[TotalNetworkCards] - [WiredNetworkCards] - [WirelessNetworkCards]\";\r\n            this.OtherNetworkCards.Name = \"OtherNetworkCards\";\r\n            // \r\n            // OtherSensors\r\n            // \r\n            this.OtherSensors.DataMember = \"Computers.ComputerHardware\";\r\n            this.OtherSensors.Expression = \"[TotalSensors] - [VoltageSensors] - [TempSensors]\";\r\n            this.OtherSensors.Name = \"OtherSensors\";\r\n            // \r\n            // SoftwarePrinters\r\n            // \r\n            this.SoftwarePrinters.DataMember = \"Computers.ComputerHardware\";\r\n            this.SoftwarePrinters.Expression = \"[TotalPrinters] - [HardwarePrinters]\";\r\n            this.SoftwarePrinters.Name = \"SoftwarePrinters\";\r\n            // \r\n            // TotalMemoryText\r\n            // \r\n            this.TotalMemoryText.DataMember = \"Computers.ComputerHardware\";\r\n            this.TotalMemoryText.Expression = \"Iif([TotalMemory] >= 1024, Concat(Iif([TotalMemory] % 1024 == 0, Round([TotalMemo\" +\r\n                \"ry] / 1024), Round([TotalMemory] / 1024, 2)), \\\' GB\\\'), Concat([TotalMemory], \\\' MB\" +\r\n                \"\\\'))\";\r\n            this.TotalMemoryText.Name = \"TotalMemoryText\";\r\n            // \r\n            // InternalDriveText\r\n            // \r\n            this.InternalDriveText.DataMember = \"Computers.ComputerDrives\";\r\n            this.InternalDriveText.Expression = resources.GetString(\"InternalDriveText.Expression\");\r\n            this.InternalDriveText.Name = \"InternalDriveText\";\r\n            // \r\n            // InternalDrives\r\n            // \r\n            this.InternalDrives.DataMember = \"Computers.ComputerDrives\";\r\n            this.InternalDrives.Expression = \"[][[DriveType] == \\\'Internal\\\'].Count()\";\r\n            this.InternalDrives.Name = \"InternalDrives\";\r\n            // \r\n            // InternalDriveSize\r\n            // \r\n            this.InternalDriveSize.DataMember = \"Computers.ComputerDrives\";\r\n            this.InternalDriveSize.Expression = \"[][[DriveType] == \\\'Internal\\\'].Sum([DriveSize])\";\r\n            this.InternalDriveSize.FieldType = DevExpress.XtraReports.UI.FieldType.Float;\r\n            this.InternalDriveSize.Name = \"InternalDriveSize\";\r\n            // \r\n            // NeedsReview\r\n            // \r\n            this.NeedsReview.DataMember = \"Computers.ComputerDrives\";\r\n            this.NeedsReview.Expression = \"[][[SmartAttributeFailed] > 0].Count()\";\r\n            this.NeedsReview.Name = \"NeedsReview\";\r\n            // \r\n            // OpticalDrives\r\n            // \r\n            this.OpticalDrives.DataMember = \"Computers.ComputerDrives\";\r\n            this.OpticalDrives.Expression = \"[][[DriveType] == \\\'Optical\\\'].Count()\";\r\n            this.OpticalDrives.Name = \"OpticalDrives\";\r\n            // \r\n            // OtherDriveText\r\n            // \r\n            this.OtherDriveText.DataMember = \"Computers.ComputerDrives\";\r\n            this.OtherDriveText.Expression = resources.GetString(\"OtherDriveText.Expression\");\r\n            this.OtherDriveText.Name = \"OtherDriveText\";\r\n            // \r\n            // OtherDrives\r\n            // \r\n            this.OtherDrives.DataMember = \"Computers.ComputerDrives\";\r\n            this.OtherDrives.Expression = \"[][[DriveType] == \\\'Other\\\'].Count()\";\r\n            this.OtherDrives.Name = \"OtherDrives\";\r\n            // \r\n            // OtherDriveSize\r\n            // \r\n            this.OtherDriveSize.DataMember = \"Computers.ComputerDrives\";\r\n            this.OtherDriveSize.Expression = \"[][[DriveType] == \\\'Other\\\'].Sum([DriveSize])\";\r\n            this.OtherDriveSize.FieldType = DevExpress.XtraReports.UI.FieldType.Float;\r\n            this.OtherDriveSize.Name = \"OtherDriveSize\";\r\n            // \r\n            // DriveType\r\n            // \r\n            this.DriveType.DataMember = \"Computers.ComputerDrives\";\r\n            this.DriveType.Expression = resources.GetString(\"DriveType.Expression\");\r\n            this.DriveType.Name = \"DriveType\";\r\n            // \r\n            // InternalDriveUsed\r\n            // \r\n            this.InternalDriveUsed.DataMember = \"Computers.ComputerDrives\";\r\n            this.InternalDriveUsed.Expression = \"[][[DriveType] == \\\'Internal\\\'].Sum([DriveUsed])\";\r\n            this.InternalDriveUsed.FieldType = DevExpress.XtraReports.UI.FieldType.Float;\r\n            this.InternalDriveUsed.Name = \"InternalDriveUsed\";\r\n            // \r\n            // OtherDriveUsed\r\n            // \r\n            this.OtherDriveUsed.DataMember = \"Computers.ComputerDrives\";\r\n            this.OtherDriveUsed.Expression = \"[][[DriveType] == \\\'Other\\\'].Sum([DriveUsed])\";\r\n            this.OtherDriveUsed.FieldType = DevExpress.XtraReports.UI.FieldType.Float;\r\n            this.OtherDriveUsed.Name = \"OtherDriveUsed\";\r\n            // \r\n            // ComputerLocalAddressText\r\n            // \r\n            this.ComputerLocalAddressText.DataMember = \"Computers\";\r\n            this.ComputerLocalAddressText.Expression = \"Iif([ComputerNetworkCards].Exists() And Not IsNullOrEmpty([ComputerNetworkCards.I\" +\r\n                \"PAddress]), [ComputerNetworkCards.IPAddress], [ComputerLocalIP])\";\r\n            this.ComputerLocalAddressText.Name = \"ComputerLocalAddressText\";\r\n            // \r\n            // ComputerMACText\r\n            // \r\n            this.ComputerMACText.DataMember = \"Computers\";\r\n            this.ComputerMACText.Expression = \"Iif([ComputerNetworkCards].Exists() And Not IsNullOrEmpty([ComputerNetworkCards.M\" +\r\n                \"ACAddress]), [ComputerNetworkCards.MACAddress], [ComputerMAC])\";\r\n            this.ComputerMACText.Name = \"ComputerMACText\";\r\n            // \r\n            // ComputerNetworkShares\r\n            // \r\n            this.ComputerNetworkShares.DataMember = \"Computers\";\r\n            this.ComputerNetworkShares.Expression = \"Len([ComputerShares]) - Len(Replace([ComputerShares], \\\':\\\', \\\'\\\')) - (Len([ComputerS\" +\r\n                \"hares]) - Len(Replace([ComputerShares], \\\'$\\\', \\\'\\\')))\";\r\n            this.ComputerNetworkShares.Name = \"ComputerNetworkShares\";\r\n            // \r\n            // ComputerLastStartup\r\n            // \r\n            this.ComputerLastStartup.DataMember = \"Computers\";\r\n            this.ComputerLastStartup.Expression = resources.GetString(\"ComputerLastStartup.Expression\");\r\n            this.ComputerLastStartup.Name = \"ComputerLastStartup\";\r\n            // \r\n            // ComputerLastLogin\r\n            // \r\n            this.ComputerLastLogin.DataMember = \"Computers\";\r\n            this.ComputerLastLogin.Expression = \"Iif(Contains([ComputerUsername], \\\',\\\'), Substring([ComputerUsername], 0, CharIndex\" +\r\n                \"(\\\',\\\', [ComputerUsername])), [ComputerUsername])\";\r\n            this.ComputerLastLogin.Name = \"ComputerLastLogin\";\r\n            // \r\n            // MemoryText\r\n            // \r\n            this.MemoryText.DataMember = \"Computers.ComputerHardware\";\r\n            this.MemoryText.Expression = resources.GetString(\"MemoryText.Expression\");\r\n            this.MemoryText.Name = \"MemoryText\";\r\n            // \r\n            // ComputerRAMUsed\r\n            // \r\n            this.ComputerRAMUsed.DataMember = \"Computers\";\r\n            this.ComputerRAMUsed.Expression = \"Round([ComputerRAMSize] - [ComputerRAMFree], 0)\";\r\n            this.ComputerRAMUsed.FieldType = DevExpress.XtraReports.UI.FieldType.Int16;\r\n            this.ComputerRAMUsed.Name = \"ComputerRAMUsed\";\r\n            // \r\n            // ComputerCPUSpeedText\r\n            // \r\n            this.ComputerCPUSpeedText.DataMember = \"Computers\";\r\n            this.ComputerCPUSpeedText.Expression = resources.GetString(\"ComputerCPUSpeedText.Expression\");\r\n            this.ComputerCPUSpeedText.Name = \"ComputerCPUSpeedText\";\r\n            // \r\n            // DrivePercent\r\n            // \r\n            this.DrivePercent.DataMember = \"Computers.ComputerDrives\";\r\n            this.DrivePercent.Expression = \"Round(Iif([DriveSize] > 0, (ToFloat([DriveUsed]) / ToFloat([DriveSize])) * 100f, \" +\r\n                \"0f))\";\r\n            this.DrivePercent.Name = \"DrivePercent\";\r\n            // \r\n            // DriveUsedText\r\n            // \r\n            this.DriveUsedText.DataMember = \"Computers.ComputerDrives\";\r\n            this.DriveUsedText.Expression = resources.GetString(\"DriveUsedText.Expression\");\r\n            this.DriveUsedText.Name = \"DriveUsedText\";\r\n            // \r\n            // DriveSizeText\r\n            // \r\n            this.DriveSizeText.DataMember = \"Computers.ComputerDrives\";\r\n            this.DriveSizeText.Expression = resources.GetString(\"DriveSizeText.Expression\");\r\n            this.DriveSizeText.Name = \"DriveSizeText\";\r\n            // \r\n            // DriveSmartFailedText\r\n            // \r\n            this.DriveSmartFailedText.DataMember = \"Computers.ComputerDrives\";\r\n            this.DriveSmartFailedText.Expression = \"Iif([SmartAttributeFailed] > 0, \\\'FAIL\\\', \\\'OK\\\')\";\r\n            this.DriveSmartFailedText.Name = \"DriveSmartFailedText\";\r\n            // \r\n            // ComputerDriveUsedPct\r\n            // \r\n            this.ComputerDriveUsedPct.DataMember = \"Computers\";\r\n            this.ComputerDriveUsedPct.Expression = \"Iif([ComputerDrives.InternalDriveSize] <> 0f, Round([ComputerDrives.InternalDrive\" +\r\n                \"Used] / [ComputerDrives.InternalDriveSize] * 100, 0), 0f)\";\r\n            this.ComputerDriveUsedPct.Name = \"ComputerDriveUsedPct\";\r\n            // \r\n            // BookmarkComputer\r\n            // \r\n            this.BookmarkComputer.DataMember = \"Computers\";\r\n            this.BookmarkComputer.Expression = \"Concat([ComputerName], \\\' (\\\', [ComputerID], \\\')\\\')\";\r\n            this.BookmarkComputer.Name = \"BookmarkComputer\";\r\n            // \r\n            // BookmarkClient\r\n            // \r\n            this.BookmarkClient.DataMember = \"Computers\";\r\n            this.BookmarkClient.Expression = \"Concat([ClientName], \\\' (\\\', [ClientID], \\\')\\\')\";\r\n            this.BookmarkClient.Name = \"BookmarkClient\";\r\n            // \r\n            // BookmarkLocation\r\n            // \r\n            this.BookmarkLocation.DataMember = \"Computers\";\r\n            this.BookmarkLocation.Expression = \"Concat([LocationName],  \\\' (\\\', [LocationID], \\\')\\\')\";\r\n            this.BookmarkLocation.Name = \"BookmarkLocation\";\r\n            // \r\n            // ComputerRAMUsedPct\r\n            // \r\n            this.ComputerRAMUsedPct.DataMember = \"Computers\";\r\n            this.ComputerRAMUsedPct.Expression = \"Round(ToFloat([ComputerRAMSize] - [ComputerRAMFree]) / ToFloat([ComputerRAMSize])\" +\r\n                \" * 100,0)\";\r\n            this.ComputerRAMUsedPct.Name = \"ComputerRAMUsedPct\";\r\n            // \r\n            // BaseComputer\r\n            // \r\n            this.Bands.AddRange(new DevExpress.XtraReports.UI.Band[] {\r\n                        this.topMarginBand1,\r\n                        this.detailBandComputer,\r\n                        this.bottomMarginBand1,\r\n                        this.PageHeader,\r\n                        this.PageFooter,\r\n                        this.ReportHeader});\r\n            this.Bookmark = \"Computer Base by Computer\";\r\n            this.CalculatedFields.AddRange(new DevExpress.XtraReports.UI.CalculatedField[] {\r\n                        this.ReportName,\r\n                        this.ReportDescription,\r\n                        this.ReportParameters,\r\n                        this.ClientGroupText,\r\n                        this.LocationGroupText,\r\n                        this.PatchScheduleDay,\r\n                        this.PatchScheduleEnd,\r\n                        this.OtherNetworkCards,\r\n                        this.OtherSensors,\r\n                        this.SoftwarePrinters,\r\n                        this.TotalMemoryText,\r\n                        this.InternalDriveText,\r\n                        this.InternalDrives,\r\n                        this.InternalDriveSize,\r\n                        this.NeedsReview,\r\n                        this.OpticalDrives,\r\n                        this.OtherDriveText,\r\n                        this.OtherDrives,\r\n                        this.OtherDriveSize,\r\n                        this.DriveType,\r\n                        this.InternalDriveUsed,\r\n                        this.OtherDriveUsed,\r\n                        this.ComputerLocalAddressText,\r\n                        this.ComputerMACText,\r\n                        this.ComputerNetworkShares,\r\n                        this.ComputerLastStartup,\r\n                        this.ComputerLastLogin,\r\n                        this.MemoryText,\r\n                        this.ComputerRAMUsed,\r\n                        this.ComputerCPUSpeedText,\r\n                        this.DrivePercent,\r\n                        this.DriveUsedText,\r\n                        this.DriveSizeText,\r\n                        this.DriveSmartFailedText,\r\n                        this.ComputerDriveUsedPct,\r\n                        this.BookmarkComputer,\r\n                        this.BookmarkClient,\r\n                        this.BookmarkLocation,\r\n                        this.ComputerRAMUsedPct});\r\n            this.DataMember = \"Computers\";\r\n            this.DisplayName = \"Computer Base\";\r\n            this.Margins = new System.Drawing.Printing.Margins(50, 50, 50, 50);\r\n            this.Name = \"BaseComputer\";\r\n            this.PageHeight = 1100;\r\n            this.PageWidth = 850;\r\n            this.ScriptLanguage = DevExpress.XtraReports.ScriptLanguage.VisualBasic;\r\n            this.StyleSheet.AddRange(new DevExpress.XtraReports.UI.XRControlStyle[] {\r\n                        this.ReportTitle,\r\n                        this.ReportParameter,\r\n                        this.Header1,\r\n                        this.LabelCopy,\r\n                        this.BodyCopy,\r\n                        this.ValueCopy,\r\n                        this.Header2});\r\n            this.Tag = \"1.0.1005.2\";\r\n            this.Version = \"14.2\";\r\n            ((System.ComponentModel.ISupportInitialize)(this)).EndInit();\r\n        }\r\n    }\r\n}\r\0',0,'8a3d873e-ae76-4896-b92f-e29be6950910');
mmoyse
Re: Report missing?
Post by mmoyse »
That didn't work
1 queries executed, 0 success, 1 errors, 0 warnings
Query: INSERT INTO `ltreports` (`ReportTitle`,`ReportCategoryID`,`DateAdded`,`UserIDAdded`,`DateLastUpdate`,`UserIDLastUpdate`,`Descrip...
Error Code: 1136
Column count doesn't match value count at row 2
Which is remarkably similar to an error message I've reported before that I'm getting:-
LTAgent  v210.82	 - 5/27/2021 12:43:59 AM	 - Plugin Error ChocolateyForAutomate, Version=3.0.0.41, Culture=neutral, PublicKeyToken=null: SetSQLColumn count doesn't match value count at row 2:::
LTAgent  v210.82	 - 5/27/2021 12:46:54 AM	 - Plugin Error ChocolateyForAutomate, Version=3.0.0.41, Culture=neutral, PublicKeyToken=null: SetSQLColumn count doesn't match value count at row 2:::
LTAgent  v210.82	 - 5/27/2021 12:49:50 AM	 - Plugin Error ChocolateyForAutomate, Version=3.0.0.41, Culture=neutral, PublicKeyToken=null: SetSQLColumn count doesn't match value count at row 2:::
LTAgent  v210.82	 - 5/27/2021 12:53:27 AM	 - Plugin Error ChocolateyForAutomate, Version=3.0.0.41, Culture=neutral, PublicKeyToken=null: SetSQLColumn count doesn't match value count at row 2:::
LTAgent  v210.82	 - 5/27/2021 12:56:23 AM	 - Plugin Error ChocolateyForAutomate, Version=3.0.0.41, Culture=neutral, PublicKeyToken=null: SetSQLColumn count doesn't match value count at row 2:::
LTAgent  v210.82	 - 5/27/2021 1:00:19 AM	 - Plugin Error ChocolateyForAutomate, Version=3.0.0.41, Culture=neutral, PublicKeyToken=null: SetSQLColumn count doesn't match value count at row 2:::
LTAgent  v210.82	 - 5/27/2021 9:44:33 AM	 - Plugin Error ChocolateyForAutomate, Version=3.0.0.42, Culture=neutral, PublicKeyToken=null: SetSQLColumn count doesn't match value count at row 2:::
Re: Report missing?
Hmmm.. that's odd.. I can reproduce error but when I count fields I get 10 columns and 10 values. So not seeing the issue as an obvious error. Not seeing any special cars causing issues so I will need to look at the issue further. When I remove the Report Data and replace it with a small text line it works so there is something in the data causing it fail.
Ill tinker with it..
mmoyse
Re: Report missing?
Post by mmoyse »
In desperation trying to get any of this to work, I removed the plugin, removed all the tables, restarted the server and went through the installation process again hoping that the report would appear, sadly it did not and the errors persists.
Getting a little frustrated with it now as nothing seems to be working, no report, no rollout of software.
mmoyse
Re: Report missing?
Post by mmoyse »
<Bump>
The report is still missing
