Can't add apps - v. 3.0.0.40
brainstomp
Post by brainstomp »
Gang,
trying to switch from Chocolatey for Labtech to Chocolatey for Automate.
When I go to add my apps to Chocolatey for Automate I get the following error no matter what app I try to add.
Yes I have checked the app is called that in the repository.
with the coco install command to make sure it isn't just bad documentation
Screen Shot 2021-03-08 at 13.51.39.png (320.5 KiB) Viewed 2689 times
with just the app name as is noted in the documentation
Screen Shot 2021-03-08 at 13.49.32.png (421.44 KiB) Viewed 2689 times
Re: Can't add apps - v. 3.0.0.40
This is a common issue with new users.
See the post here , explains what you need to do.
viewtopic.php?f=5&t=5769&sid=9d61b23f76 ... 52128e0354
