Chocolatey stuck on 540 pending commands
JLOVE
Post by JLOVE »
On November 25 during the Thanksgiving Holiday break I installed the plugin and messed around with Chocolatery for Automate. While messing around with it I picked out 16 packages and i accidentally told it deploy them all. I unchecked the boxes for the applications that i don't want deployed to all my computers. However it has been stuck on 540 pending commands since the 25th or 26th. The last execution time is changing every day. But i don't think its actually installing applications. Got any ideas?
Re: Chocolatey stuck on 540 pending commands
You should have a log on the LThost for all plugin activity.
C:\programdata\labtech\logs\plugin_pluginName.log
Send that to us so we can see what the system is doing.
JLOVE
Post by JLOVE »
I am using the hosted version of Automate so how do i get that log file? Thanks.
I believe you can request it from CW support or if your using our Habitat Plugin then we provide log readers for all plugin log files on LT Host.
https://www.plugins4automate.com/collec ... te-build42
