is there a way to set the install for a package automatically using automate groups?
We have quite a lot packages we want to deploy to just a few devices. Right now the only way we see, is to allow installs on the client and afterwards get to every device and uncheck install, except the devices the package shall be installed on.
We have clintes with several hundreds of devices and that´s not really an option to do it like that.
Or is there a way to enable a packe on a device, if install is not enabled on the client?
Or is that a feature if use chocolaty for labtech instead of for automate?
marc
set the choice of install in automate
Jump to
- ↳ Scripts
- ↳ Automate Package Manager
- ↳ Documentation
- ↳ Patch Remedy 5
- ↳ Documentation Project
- ↳ Chocolatey Plugins
- ↳ App Genie
- ↳ Chocolatey For Labtech
- ↳ Chocolatey For Automate
- ↳ Chocolatey For Automate 3.6 Document Project
- ↳ Habitat
- ↳ Office365 For Automate
- ↳ Office365 for LabTech
- ↳ Defender For Automate
- ↳ Defender Documentation
- ↳ Active Directory UC
- ↳ BitLocker for Automate
- ↳ SurfLog for Automate
- ↳ Silo For Automate
- ↳ Cleaner For LabTech
- ↳ Printer Status Plugin
- ↳ Linux Update Manager
- ↳ Magma For LabTech
- ↳ Nagios for LabTech
- ↳ Map Drives Plugin
- ↳ Agent Status Plugin
- ↳ Flue Shot AV Plugin
- ↳ Net Detective plugin
- ↳ SQL Query Analyzer plugin
- ↳ PFSense 4 LabTech
