Install on agent failing
TeeEm
Post by TeeEm »
Hi, I have enabled and approved a few packages at global level. Then enabled for a client. When i try and install or upgrade a package i get "Supporting POSH file is missing, exiting script." any pointers on what's missing. Most of the agents already have chocolatey installed and previously may have had app genie as well.
Re: Install on agent failing
Interesting?
Can you verify your script versions and Chocolatey build numbers?
We are on "Chocolatey For LabTech Maintenance Service"
Update 09/11/2020
Version 2.0.1.98
Or are you on Chocolatey For Automate?
ilyak
Post by ilyak »
I have the same issue. The script P4L Chocolatey For LabTech Maintenance Service description has the following
This is a maintenance script used by the Chocolatey for Automate Plugin. Not for manual execution.
www.plugins4automate.com
http://support.plugins4automate.com
Auhor:Shannon Anderson
Date:06/09/2020
Version 3.0.0.35
Plugin manager also says 3.0.0.35
