So we have "Memory" returning false positive data on two hosts, so I went into the CIM data field and Disabled that specific one but it still logs tickets every time.
I've attached a screenshot of it being disabled and it still showing critical in the main view, all of the other options are green.
Alerting even when CIM is disabled
- Capture.PNG (82.99 KiB) Viewed 15084 times
Re: Alerting even when CIM is disabled
Can you verify that probe is requesting data for HP style systems. Then we need to look at the code that is returned and verify that code = "Non-recoverable error" if that code number should not = that status code then changing the code for HP in the plugin database to "OK" will resolve the error.
If the code is accurate can you send us you plugin build number?
Yep both are set to HP. I'm not sure what you're referring to in regards to the code that is returned.
The plugin build number is 4.0.0.63
When you set up probe to scan host, did you set probe to scan as a HP, Dell, Intel or other ?
It is setup as HP
Perfect, that's one less issue. HP verses basically everyone else has different status codes for error conditions so you need to be using the correct mappings.
Which you are.
In your image, the first screen has a red X on it. If you hover you mouse over it it will provide the full status line for the ESX host. Can you post that information here?
This main status is set directly from a CIM status request so the ESX host believes its in error as it is reporting back "Error". After this first request we request CIM data for hardware. (ESX Host status / Hardware Status)
So we are trying to disable the current status, the CIM data segment has already been suppressed?
In our current logic we assumed enable / disable in CIM data allows you to control false CIM data alarms with objects that maybe missing or errors in statuses that would not cause the HOST to error.
I can look at what it would need to disable the main status but we would want to make sure to manage those statuses being disabled so if the status message changed for a given host a new alarm would be generated. Otherwise you would just stop getting alarms for a Host and that could be a bad thing. I how ever could see a need for a master disable on host alarms as another option from status disabling.
I will need to toy with this a little bit...
We're having the same issue also. In the customer view the server goes back green for the status when disabling the CIM we don't need/want but in the main view, it still shows as an error.
Here's screenshots of everything I think will help
The fact both hosts are returning the same error, it's got to be a BIOS bug or something in VMware, because vCenter shows no errors yet when you query directly it does. If there's anything you want me to do further let me know, I can have SSH access directly to the hosts if you need me to
- Capture.PNG (37.65 KiB) Viewed 14631 times
- errors.PNG (69.32 KiB) Viewed 14631 times
Any news on this? Keen to get this sorted as it will make monitoring servers much easier!
