Scan Results Not Populating in Plugin
FraserCT
Post by FraserCT »
We have a problem whereby the scan results returned from the script are not populating in the plugin. Up-to-date AD export to SQL is on the machine but then is not pulled into the CWA DB.
Has anyone seen this before?
Re: Scan Results Not Populating in Plugin
Frrce a scan and then watch the agent script logs to see results returned.
Post that here..
FraserCT
Post by FraserCT »
Sorry for the delayed reply. I have pushed the AD scan by clicking apply on the plugin but the script is now not showing in the script log for the machine.
I am assuming your getting
Would you like to run a scan of the AD server now? and selecting OK?
If so then I think I see the issue, Automate now expects a extra field when scheduling scripts and this plugin does not pass that.
I will have a fix out for this today.
Here we go,
Build 1.0.1.26
https://delivery.shopifyapps.com/-/4794 ... fe88cb4790
Should fix script scheduling
FraserCT
Post by FraserCT »
Thank you very much! Works a treat now.
