3rd party app addition
MarkHodges
Post by MarkHodges »
New to choco in general. Was looking at adding Zoom.
I tried Zoom% and it looked like it picked up quite a fiew apps so I reverted to just using Zoom and it seems to be targeting the correct zoom client
https://chocolatey.org/packages/zoom-client
I added it with the package name zoom-client
On a machine I can see it shows Zoom installed and a 4.6 Package version but the Repo version is none....
did I do something wrong?
Re: 3rd party app addition
Need to allow 24 hours or so for the scans to pickup the new software title. If after new scans from agent have completed a repo version should appear.
MarkHodges
you are correct...it was looking correct today (although every app on every agent was showing error) but rescan seems to have fixed it)
