Error 2281 - bad data...the file does not have a '.ps1' extension
RSCS
Post by RSCS »
When we initiate a scan, each client generates the following error:
Processing [customer] -> Client Failed Update
2281 - bad data or errors returned - Processing -File '-Office365Username' failed because the file does not have a '.ps1' extension. Specify a valid Windows PowerShell script file name, and then try again.
How do I resolve this?
Thanks,
Dean
Re: Error 2281 - bad data...the file does not have a '.ps1' extension
Looks like your username maybe causing an issue. Does it have any odd chars in it? Something that when placed between a set of quotes (" * ") that would otherwise break a call to a powershell script as arguments?
Also see this post on how to debug scans
http://support.plugins4automate.com/vie ... 9a905d16cf
RSCS
Post by RSCS »
Thanks Cubert,
Actually, oddly enough, after it shows that error, it continues to process the two clients that we have set up in the plugin. There is an error for both of the clients.
The first one has been in place for a couple of months and appears to still be working. For the second one, it shows all of the O365 Distribution lists with the member accounts. These DL's appear in the plugin for the client but no other information appears. All of the Status detail on the Azure tab is blank or grey, there are no items in Exchange or Licensing. Just the Groups and MSOL Status.
I feel like I have two issues. 1) The error appears for both the working and non-working client. 2) the second client has no account or status info.
There are no other error messages in the debug window.
How do we proceed?
Thanks,
Dean
If you would, select only Azure, in the scanner windows and run in debug mode. Then post that here or email it to support@ if you need some privacy. Let us look at debug report.
greyxv
Post by greyxv »
I am running into this issue as well. Here is what I've done so far to troubleshoot.
1. Changed scanner to different devices on different networks and different operating systems.
2. Changed credentials and verified usernames did not have symbols.
3. Verified modules were installed successfully.
I can't even seem to get Azure AD to scan properly. Below is what I get after enabling debug mode.
Thanks for your help.
Checking MSOnline Modules are in the 64bit PoSh folder
2 - 1.0.9031.1
Test for MSOLUSERS functions on probe
Found current MSOLUSERS
Executing MSOL User Scans on [1] Clients
Processing [] -> Client Failed Update
2 - bad data or errors returned - Processing -File '-Office365Username' failed because the file does not have a '.ps1' extension. Specify a valid Windows PowerShell script file name, and then try again.
Windows PowerShell
Copyright (C) 2016 Microsoft Corporation. All rights reserved.
aspendora
Post by aspendora »
I'm having the same problem. Was there ever a resolution for this? I sent in a request to support@plugins4automate.com but have not heard back yet.
We are looking into this error. Looks like it maybe having issues with command structure now.
I'll post an update as we get them.
rspaulding
Post by rspaulding »
I am having this exact same issue also. Are there any updates on this?
