Apps won;t install
pbosak
Apps won;t install
Post by pbosak »
Hi, i installed and deploy Chocolatey to workstation. But when i push installation several apps, nothing happen. How to fix it ?
Re: Apps won;t install
Nothing happens how?
Can you post any views, script logs, agent commands, errors or alarms received from what you did?
Understanding that Chocolatey Plugin uses scripts and commands to agents to do things. Each of those are logged and are available to follow along with the functions called. There is also schedules the plugin is limited to so you may enable an agent but that agent may require several hours on first run to get prepped...
pbosak
Post by pbosak »
Maybe this is license issue.
a
a
