Hello
Plugin is simple. I setted title bar, message box, then enabled plugin and set time in global manager and... nothing happened
Of course i settted day and enabled patching for workstation on client site.
Any idea ?
I use Automate v12
Plugin does not work
- 1.jpg (99.86 KiB) Viewed 206288 times
Re: Plugin does not work
Can you confirm the following for the location for which the agent is in.
Also, the message box is a VB(Messagebox) which is looking for a simple string of text. So just for giggles make a simple message with no "crlf" in it.
Example:
Example:
The above message is has no line breaks that could cause message to fail to display.The management will be performing maintenance on your PC this evening. Please log out of your PC but leave the PC running before you go home today. Thanks, the Management
- 6
I haven't tried this yet, but it work with the new patching in version 19?
We are working on a new version for the latest Automate builds now that they do things differently.
