Patch remedy update loop
Re: Patch remedy update loop
yeap that will work, then make that output saved to the Script variable being used to test and you should be good.
ObeliskStreet
Post by ObeliskStreet »
Blootech or Cubert, could you take some screenshots of exactly what you have changed for this? I tried to follow but it's still doing the same thing even with the changes.
Cubert, how does this work with Patch Remedy updates? Is that script overwritten? If not, how are any problems in the script ever fixed?
Gerner
Post by Gerner »
I hadn't read through this post before making another regarding the same issue. I'm both glad and disappointed I wasn't the only one that had this issue. Hopefully you guys can fix it in the next update. There are still other issues in this script e.g. the version comparison for 1803 I mention in my post viewtopic.php?f=7&t=5797&sid=2d6336c7ae ... ca259a1862
ObeliskStreet, if you need to fix yours in the meantime I've described the change I made to my script in that post.
This has been resolved in todays release of 1.0.4.47.
Auto updates should update plugin over the next 12 to 24 hours depending on where in the world your running.
