Getting started
slpefanis
Getting started
Post by slpefanis »
Hi All
We've just purchased the plug for Automate. I've installed the plugin, but all the guide's seem to be for the older version of Automate. We are on hosted.
Can someone answer a few questions?
* When installing the plugin, do I select it as an "remote agent"?
* What is the "must do" to get started?
* Does the system automatically deploy all apps to all computers in that group?
* Whats the best way to "test" this to a small group of PC's?
Re: Getting started
Re: Getting started
The basics would be...
#1 Create a global App list and allow installs and updates
#2 At the client level Enable and approve from the global app list what apps you want this client to have or manage.
#3 Now allow for 24 hours to pass before expecting everything to get rolling.
There are several things that have to happen across alot of agents so allowing time for that to all shuffle out is good.
slpefanis
Re: Getting started
Post by slpefanis »
Thanks.
For the "Deploy a polling agent", I can't seem to deploay to Server ID 1 and Sys Admin "System".
Any suggestions on where I can find this data?
Re: Getting started
If your not an on prem server then this option is not available to you. Its looking for the agent ID of the LTHost.
slpefanis
Re: Getting started
Post by slpefanis »
I'm hosted, how do I then use the "Poll" option within the application or doesn't it apply to hosted options.
