Overview - Increase the chart's size, to view its layout.
dlee
Post by dlee »
I tried to use the search feature here with Increase the chart's size, to view its layout. but the search replied that none of the words used were valid words. So here we are:
I went to configure > Refresh View and then went to Overview and the graph on the front had two titles. I did it again and it had 3, again and it had 4. Until finally it now says to increase the chart's size, as if all of those titles made the graph info too big. So here we are.
Any ideas? Attached.
PR Increase Chart Size.PNG (140.69 KiB) Viewed 9166 times
dlee
Re: Overview - Increase the chart's size, to view its layout.
Post by dlee »
Resolution: This issue went away overnight after scans were completed and I guess the chart was "refreshed." If there's anyone out there who knows why this occurred or can offer up more details, the forum appreciates the response in advance. Thanks.
What happens is the size of the window the plugin graph consumes is to small to display the chart. When this warning shows you can just take the plugin window and maximize it to full screen and that will (in most cases) provide the room needed for all elements of the chart to be included.
We try to limit this to 30 items but if window is to small 30 items will not fit and the chart displays this warning.
