Registry Scans fail to return data to plugin.
If your having issues running Reg Scan with plugin and see that it fails every two or three tries then your most likely hitting the Automates Script Engines 15 minute time out for executing commands.
There is one way to help reduce the time to scan, Removing selections will reduce the scan time and may allow scans to complete in a timely fashion. See images below where we turned off most of the scan options then ran a scan. Scan took 2 minutes to complete and data was displayed as expected. Depending on the size of a registry this time value will change. Some settings may work fine on one system and not another based on the sizes.
The scan started at 10:53 and ended at 10:54 with data
