Feature Request for Windows 10 Upgrades- Reset upgrade log on multiple machines.
jmaxwell
Post by jmaxwell »
If it's possible, it would be great if we could reset the upgrade logs on multiple machines rather than one at a time. If this already exists, please inform me how to do so.
Re: Feature Request for Windows 10 Upgrades- Reset upgrade log on multiple machines.
You should be able to multi select agents from list and enable / disable / run now upgrades.
Is there another control you would like to see at the main window for multiple agents?
jmaxwell
Post by jmaxwell »
To clarify, you are talking about the option in the right click to 'enable upgrades', ' disable upgrades'? This is the option to defer upgrades correct?
Toggling this option will reset the the upgrade log?(Right click> View upgrade log> reset log)
I can't think of another control to be incorporated besides the separate ability to reset the upgrade logs on multiple machines at once.
Select multiple agents and then using these 2 controls you can apply to multiple agents at one time. This will setup upgrades for agents.
jmaxwell
Post by jmaxwell »
Ok thanks for the info. However, due to the issue on the following thread, we are not able to change from yes to no
viewtopic.php?f=7&t=5477
That is now fixed in build 1.0.4.33 due out tonight in the auto upgrader and is now available for download if you log into your portal at www.plugins4automate.com
