Last Update Error [V 3.0.0.16]
IT-Kompass
Post by IT-Kompass »
Hello Everyone,
i have installed the Chocolatey beta plugin and get the Error message (see Attachment) in the plugin.
The Error appears on the Client and The Server directly and starting Automate as admin or normal.
I can add applications, but only directly on the server.
Thanks for the help,
Max
Re: Last Update Error [V 3.0.0.16]
This error says that LT is having issues checking for updated versions of approved softwares. This is a soft failure and should not impede basic operation.
If it does not clear then send us the logs for the plugin off the server so we can see what its not doing.
c:\program files\labtech\logs\plugin_chocolateyforautomate.txt
Shannon
IT-Kompass
In the rar file are all log files from the \logs folder.
The Error exists since the installation circa one week ago.
Max
Choco_Logs.rar
(20.45 KiB) Downloaded 723 times
Yeap from logs looks like we have a SQL error
SetSQLColumn count doesn't match value count at ...
This is the code that updates the package versions data as available.
Let us look into this and see whats up and if we can duplicate.
IT-Kompass
That would be great.
Thank you.
JeroldW
Post by JeroldW »
Hi Cubert, I've had the same error. Any solutions on the horizon?
Yes, we will be updating this plugin shortly.
rniggemann
Post by rniggemann »
It has been 3 months since the last message on this thread. I, too, am having this issue. Will there be an update to the plugin soon?
