CCleaner Feature Request
scripts4life
Re: CCleaner Feature Request
Post by scripts4life »
I am very excited about a new CCleaner release though.
Will this work for Labtech 10.5
Sure will,
europait
Post by europait »
Cubert wrote: Fri Mar 04, 2016 8:15 pm Ask and ye shall receive, Here is a predeployment script that you can use to launch cleaning of a system as a Monitor Action.
Import this script and use it as the script to run when alarm hits, edit script and make sure that line 2 is pointing to the Cleaner Maintenance Service script under the Maintenance folder.
Enjoy!
Cleaner_For_LabTech_AutoClean .zip
Can you repost this script. It seems to be expired and I cant find it in our system, I thought that I had imported before but I guess not.
here you go...
(6.58 KiB) Downloaded 1043 times
