FileHog config save error, Error There is no row at position 0
JacoLange
Post by JacoLange »
Hi there
I installed FileHog on LT 11
When I open the Plugin I go to Configure put in C: for the drive and under Pattern i put in *.pst
I then click on save config, a error pops up as follow: FileHog config save error, Error There is no row at position 0
I click on Ok, this takes error away but no results is returned for serach, What cause this error and how Do I fix It
Jaco
JacoLange
Re: FileHog config save error, Error There is no row at position 0
Post by JacoLange »
Found the Problem:
forgot to import the FileHog-Scripts-1.0.4.xml Script
after import it works fine.
Yea, thats an older plugin so does not automatically bring in scripts and such like our more recent plugins do. We need to circle back around to some of these older plugins and give them a good refresh.
Return to “FileHog File Analyzer Plugin”
