Released build 1.0.3.36
BlairMunro
Re: Released build 1.0.3.36
Post by BlairMunro »
Hi Cubert, what has changed in this version? Thanks!
You can find change notes in the README.txt file included with our plugins. In the case of this update we have updated the following.
We have turned on Multiple select for the following view. This allows you to select all the systems you want at once and push out the latest updates only. All other tools listed are still only 1 on 1 runs meanings you select a single system from list and that system gets the commands you send.
(Multi Select agents for updates)
BlairMunro
Cheers Cubert, love your work!
starbucksgold
Post by starbucksgold »
Shannon,
I've confirmed the multi-select works great on the WUA versions tab :)
Would love to the same option (multi-select) added to the other tabs if possible.
Jeff
