Released Build 2.0.1.82
Here is the 2.0.1.82 build of Chocolatety For Labtech https://delivery.shopifyapps.com/-/164e ... 1d4e2c2040
We added a new tab in the Client View,
Install Issues shows you the applications and the systems that are having trouble at the client level allowing you to clear the counters and allow automation the ability to re attempt installs.
revsmitty
Re: Released Build 2.0.1.82
Post by revsmitty »
I'm seeing the attached error when launching the plugin.
