Hello
Is it possible to get an export of all computers that have Bitlocker enabled/enforced?
A list of all the keys possibly?
Bitlocker Dataview
Re: Bitlocker Dataview
The data resides in the database so yes, you can export that out. We do not directly offer a export button to do that but I can look at it and see where I could add a quick export button.
- 1
Just "bumping" this post to say that we also would be interested in a way to export a list of machines with their drives, encryption status, and protectors.
- 1
Any update on this dataview? If not, where do we find this information on the database so we can at least configure a search.
You all should have this already!
As of 1.0.0.17 we added a new view that is available by clicking the Volumes List Button on main view.
Select the button will open a list view of the client with the ability to export data out to CSV/Excel. Includes password, pin and recovery passwords.
Passwords and Pins would needed of been created using our plugin, we will save that data to Automate DB in the invent of some failure.
