Trying to patch a Oracle 9.3 (Linux) system it seems to find packages but they never seem to install
Re: Trying to patch a Oracle 9.3 (Linux) system it seems to find packages but they never seem to install
roger that, Allow me a moment to see what's going on and I will get back to you.
Wow, I had a (x) where I should of had an (i).
I should have also fixed the issue with the console items in list boxes not actually making a selection and assuming the item in list that is showing was actually selected. It should now always default to the first item in each list, selected or nothing selected.
I will have update posted shortly, your auto update should pick it up tonight and update your plugin for you.
ok I see the update, we have the server set to patch Sunday at 5 am so will let it run and update you on Tuesday when I am back in the ofice.
see the commands going but get the same errors
Looks like its scanning fine, but the error is no matching packages to list.
and it never updates the systems.
and the system never is listed under agent updates, but a different ubuntu server is listed there with available updates
- 2024-02-27_08-03-55.png (15.38 KiB) Viewed 7155 times
From what I can decern,
There are maybe 2 packages that are in the package list that are failing to "get more info" when we loop through each of the available packages.
Since I do not have an Oracle box, can I have you try a few things to see if we can resolve the issues?
#1 Modify Scanner script (APM Agent Scanner)
Open line #28 (Should hold a bash script like below)
Find the highlighted code block as seen in image below.
Replace the loop (6 lines of code) with the following updated code loop.
The difference is I am now piping STDERR to null instead to terminal by adding " 2>/dev/null" to each command line we execute.
Make this change in bash script, save the LT script and then using the debug feature at the bottom of LT script, run script against the Oracle agent. It should execute script live for you to see what script is doing and what it is outputting when completed.
for package in $installed_packages; do
root_name=$(rpm -q --qf '%{NAME}\n' $package 2>/dev/null)
current_version=$(rpm -qi "$root_name" 2>/dev/null | grep "Version" | awk '{print $3}' | head -n 1)
available_version=$(yum info "$root_name" 2>/dev/null | grep "Version" | awk '{print $3}'| sort -rV | head -n 1)
a+='(%computerid%,"'$root_name'","'$current_version'","'$available_version'"),'
done
Running debug is pretty simple.
First select the agent you want to run script on.
Then select start, wait for it to initialize and then select next break. It will then start executing line by line the script. When completed it will leave a list of return variables in box. Well check the output to see if it still has errors..
I made some changes to script, and pushed out another update. Build 1.0.0.10
https://delivery.shopifyapps.com/-/5c58 ... 970b3e72e7
ok downloaded and applied update.
Made the requested change to the script.
ran debug. attached images of results it did pass and I no longer see the errors
still nothing for onboard Linux Agents Group
- Update3.png (35.11 KiB) Viewed 7146 times
- Update2.png (8.33 KiB) Viewed 7146 times
- update1.png (11.62 KiB) Viewed 7146 times
Good news it now appears to be registering correctly, as I see it listed in the agents with updates pane.
I manual told it to apply updates and it appears to be updating now, will let you know the result
- update4png.png (15.58 KiB) Viewed 7130 times
I do notice from the image above that this agent is not set to auto update.
So only manual updating will work until you adjust settings.
Remember, any agent set to auto update and does not have a policy set will test for updates daily.
