How to remove PR?
- 2
How to remove PR?
We have decided to not continue, at least for now, to use PR. What is the best way to remove this from the Automate system?
Re: How to remove PR?
Hello
try unlink the associated integration or plug-in your version control platform and after that update any relevant config . file in your workflow.
drop a reply if this help you out.
thanks.
thanks.
