Habitat IIS Loaded?
chris10385
2
Habitat IIS Loaded?
Post by chris10385 »
Just installed the Habitat plugin. Should it have an IIs piece loaded?? See screenshot as mine is not showing IIS.
habitat no iis.png (67.82 KiB) Viewed 4001 times
Re: Habitat IIS Loaded?
That fine, we have no IIS stuff to load.
chris10385
2
Thank you! Now I just need to figure out the 3rd party application manager.... we are a MSP and dont have a drive of any sort that everyone can access. Assuming we can't use OneDrive??
You have 2 choices,
At location set all agents as standalone (big locations not a good idea) or setup any workstation to share out a folder to the network . Any PC can host a network share if they are not laptops and mobile. Needs to be a desktop or system that is reasonably online when needed.
Simple set of user permissions are needed to access share.
Read /Write for the Caching manager agents and read for all other agents.
