Page 1 of 3
Windows Upgrade Assistant - Run Now and Schedule not working
Posted: Thu Jun 04, 2020 3:03 am
by michaeldiaz
We are new to this plugin and i already read this
viewtopic.php?f=62&t=5657&sid=55e3f4128 ... 68ae9ad8cf
I was able to set the Policy (Download from Google Drive), i confirmed that the Master Switch is on.
I assigned the policy to machine without issue, but when i try to schedule an upgrade, there are no scripts being scheduled to the machine. I also try running the upgrade now and it didn't work, no script run, but the Last Run field populated. See screenshot below.
Re: Windows Upgrade Assistant - Run Now and Schedule not working
Posted: Fri Jun 05, 2020 12:40 pm
Can you confirm the following scripts are present?
- Capture.PNG (81.94 KiB) Viewed 8670 times
Posted: Mon Jun 08, 2020 7:49 am
by michaeldiaz
Yes they are here:
Posted: Mon Jun 08, 2020 11:53 am
Was the schedule the same day or next day ++ ?
We just fixed (added) same day scheduling to Habitat in last build. 1.0.0.44
If you set a schedule and it is on the same day as "Today" when you set it it should now schedule that ASAP and not wait till 12 AM to set schedule. Otherwise all schedules are saved to database and then on the day of schedule it is applied to the agents script schedule at 12 am for that day.
So if you schedule for next week, you will not see script show up on agent until the day of the scheduled time.
Posted: Tue Jun 09, 2020 7:21 am
by michaeldiaz
I used Upgrade Now, and no habitat scripts has been scheduled to the agents.
I tried scheduling it for a later time (same day, current time is 3:20 AM EST and i scheduled it to 4:00 am), still no script being scheduled.
Posted: Tue Jun 09, 2020 1:22 pm
What build are you on? Want to make sure your up to date.
Posted: Tue Jun 09, 2020 10:41 pm
by michaeldiaz
I checked plugin manager and we are at 1.0.0.43.
Posted: Wed Jun 10, 2020 12:34 pm
This is the latest. I was wrong on 44, that build is still in the cooker.... This is the same version you see when opening up Habitat Console?
Posted: Wed Jun 10, 2020 12:40 pm
Can you try to schedule a update or two and let it fail.
Then right after that go grab the C:\ProgramData\LabTech Client\Log\{currentdate}_LTcErrors.txt and post it here.
We are looking for a SQL error to be present in file pretty much at the very bottom of file. Or at least we hope..
Posted: Wed Jun 10, 2020 10:33 pm
by michaeldiaz
Cubert wrote: ↑Wed Jun 10, 2020 12:34 pm
No, the build is 1.0.0.42. How to fix that?
Cubert wrote: ↑Wed Jun 10, 2020 12:40 pm
What do you mean to let it fail?
Here is what i did, i schedule the update for a later time and wait for it, nothing happens, no script ran, the Last Run field did not update.
I still tried to collect the log but the Labtech Client folder is not present, only this:
