Release Build 1.0.14
Posted: Thu May 11, 2017 5:55 pm
https://delivery.shopifyapps.com/-/904b ... aba34fa95b
Further fixes issues with Redhat/CentOS Reboot flags.
Re: Release Build 1.0.14
Posted: Mon May 15, 2017 1:42 pm
by beaver9999
I have installed the Linux Update Manager (thank you for making this by the way). Unfortunately, for me the only OS it will update is Ubuntu 16.04. I have LabTech 11 Agents installed on the following OSes but none of them will update...Centos 6, Centos 7, RedHat 7. It will successfully scan for the required updates, but when I try to install an individual update it does not work.
Is there a setting I need to enable in Linux to allow the updates to proceed?
Any assistance is much appreciated.
Thank you
Posted: Mon May 15, 2017 2:15 pm
Ok so your seeing packages for Redhat, etc.. just can't select 1 package and update. If you selected "Update all" does it do that for you?
Posted: Mon May 15, 2017 7:01 pm
by beaver9999
Just tested that (on CentOS 7). It can successfully install ALL patches. Just not when choosing individual patches.
Posted: Mon May 15, 2017 8:05 pm
Perfect, let me look into that.
