Framework not deploying with installs turned off.
Posted: Thu Nov 12, 2020 4:00 pm
Okay,
so I bought the licenses.
I started to test.
I thought I had it sorted, so I bought more licenses.
Now I ran into a problem.
If I don't exclude the client machines from installs they get every single piece of software in the chocolatey plugin setting. Even if auto-install is turned off.
If I exclude the client machines from installs then the Chocolatey framework is never installed.
So how do I deploy the chocolatey framework without it also installing every single application on the plugin software list?
I started to test.
Now installing Chocolatey framework.
Chocolatey Licenses 75 , Licenses Used 38
System ID 816 is set to be excluded. remove this setting before trying install again.
Deployment scheduling of the Chocolatey Framework is now complete.
