Stale alerts
Posted: Thu Sep 05, 2019 6:15 am
by technospecs
The plugin we have for ESX monitoring is working for most of our clients in Connectwise except two of them where it doesn't complete a scan and hence sending stale alerts. In efforts to fix this, we tried changing the probe to another server for the client and when the first scan occurred after the probe got changed, the scan worked file but then stopped again. Any idea on what can be done to fix this?
regards,
Mandeep.
Re: Stale alerts
Posted: Fri Sep 06, 2019 5:20 pm
Depending on what the return of the script calls were you can expect 1 of 3 common issues
#1 Python is missing a lib so probe fails to execute. Delete the c:\python27 on probe and rescan. Will auto reinstall python.
#2 Bad host IP, username or password. See logs in script for password errors or no connections logs
#3 ESX CIM service has died or is administratively disabled. Reboot ESX host or see our post here on how to enable a disabled CIM service. http://www.squidworks.net/2017/02/vmwar ... y-default/
Re: Stale alerts
Posted: Tue Sep 24, 2019 5:48 am
by technospecs
Hello Cubert,
Our plugin has all the previous settings disappeared and it is showing blank information on the plugin tab under the client properties. Also, if I try to add any host information back to it, it wouldn't allow me to do this and the save button is grey out. What could be the reason for this?
regards,
Mandeep.
Re: Stale alerts
Posted: Tue Sep 24, 2019 3:17 pm
License expired..
If your still have an active subscription then send me a email at support@plugins4automate.com with your email / LThost name so I can go fix your license. We occasionally get a hickup between systems and a licenses does not get updated.
Re: Stale alerts
Posted: Tue Oct 01, 2019 5:35 am
by technospecs
Hello Cubert,
I sent an email on 26th last month and have sent a follow-up email today. Can you see if there is any updated on the same?
regards,
Mandeep.
Re: Stale alerts
Posted: Tue Oct 01, 2019 2:57 pm
We just got your email today, problem was found and resolved so you should see valid data now. We needed your email address to look up account and didn't want to get that posted across the forum.
You should be good to go.
